Creative Downloads with PSPro X
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Have downloaded the picture frames and tubes into My PSP files in My Docs frames and tubes folders.How do I move them into the Picture Frame collection under the image tab or into Picture Tubes or access them from the PSPro programme ............................Ken
Tim Morrison
- Moderator
- motherboard: Asus P4533
- processor: 3.16 GHz
- ram: 2GB
- Video Card: Radeon HD4650
- Hard_Drive_Capacity: 2.6 TB
- Monitor/Display Make & Model: HP LP2275W
What exactly have you downloaded? Was it the extra content that you get for registering PSP X (English_PSPX_RegXtras.exe)? Have you run the file to extract the contents? By default, the contents are extracted to the correct folders in PSP X's installation directory, and should be available immediately... or you may need to restart PSP to see them.
If the tubes and frames have been extracted from a downloaded file, and are in TUB, PSPTUBE, PFR or PSPFRAME formats and are in the corrrect frame and tube folders in "My PSP Files", again they should already be available, or you may need to restart PSP to see them.
If you go to File > Preferences > File Locations you will see the locations where PSP will look for resource files, and if necessary you can add extra folders here as well.
Tim Morrison
C-Tech Volunteer
C-Tech Volunteer
Ken Veal
- ram: 32 GB
Downloaded Pic Tubes & Frames
I have downloaded 11 frames saved in My psp files/pic frames that have
file names like" 1_04_Frames Jan 04 Newsletter Frames", they are application files.Have also have some 23 tubes in My psp files/tubes.In the properties they were all blocked in the security field and all have been unblocked.Every file has been installed by the wizard.Have re booted but
still cannot see them in the frame and tube list in PSPro.These were not
downloaded using the programme disc but were from the Coral website.
Ken Veal
- ram: 32 GB
they were downloaded from:-
http://www.corel.com/servlet/Satellite/ ... 2796556589
Tim Morrison
- Moderator
- ram: 2GB
Unless you change the location when you run the installation file, they will be saved in a folder in the default location of a different version of PSP to the one that you have.
"1_04_Frames Jan 04 Newsletter Frames" will default to installing to C:\Program Files\Jasc Software Inc\Paint Shop Pro 8\Picture Frames, which is the PSP 8 frames folder (the current version in January 2004). It will create that folder if you do not have PSP 8 installed.
You could do one of three things.
1. Reinstall "1_04_Frames Jan 04 Newsletter Frames" and change the installation folder to your My PSP Files\Picture Frames folder
or
2. Move the contents of C:\Program Files\Jasc Software Inc\Paint Shop Pro 8\Picture Frames to your My PSP Files\Picture Frames folder.
or
3. Go to File > Preferences > File Locations > Picture Frames and add C:\Program Files\Jasc Software Inc\Paint Shop Pro 8\Picture Frames to the list of locations there.
The Tubes will be in similar locations - C:\Program Files\Jasc Software Inc\Paint Shop Pro 8\Picture Tubes for instance.
Depending on which resources you installed, you may have things installed in the PSP 9 folder (C:\Program Files\Jasc Software Inc\Paint Shop Pro 9), or maybe the PSP 7 folder as well (C:\Program Files\Jasc Software Inc\Paint Shop Pro 7).
or
or
Tim Morrison
C-Tech Volunteer
C-Tech Volunteer
Ken Veal
- ram: 32 GB
Picture Tubes & Frames
Following your advice I moved the tubes and reinstalled the frames
to My PSP files/Frames etc...........and it worked !! Thank you very much
Tim. ......................Ken
