Anyway, I notice a slight difference in the video quality of the burned discs, especially in clips where there is panning. I have been burning a project to DVD & also HDDVD to regular dvds. I used the same clips in both NLE's. I'm using HDV .m2t files, taken from my Sony hard drive recorder.
The clips in the timeline show the following properties: MPEG2 Transport, UFF, 24 bit 1440x1080 16:9, 29.97 fps, Data rate 25000 kbps, Mpeg layer 2 audio.
In Project Properties: Edit format is Mpeg, 24bit 720x480 29.97 fps, UFF, DVD-NTSC 16:9, VBR 8000. Project Options: Media type: NTSC DVD, Quality 100%, 2 Pass Encode.
In Share/Create Disc: MPeg files, 24 bit 720x480 29.97 fps, UFF, DVD NTSC 16:9, Video data rate 8000 kbps, Audio data 384 kbps, Mpeg layer 2 48khz. Stereo. Do not convert compliant mpeg files is checked.
In Disc Template Manager/Edit/Options, I see a ' Ulead MPEG Now Encoder' driver. Are other codec drivers available? Do NLE's have their own codec for burning? Could this be why the output quality is different? I really want to get this figured out so I can make UleadVS my new NLE.
