Suntan-no can do - P S Pro X
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
I select Make over then
Suntan mode -size box active, strength box not
Select Blemish Fixer- strength box active
Can alter size by alt + drag but cannot apply suntan.
Tried right clicking on subject but of no avail.
I am working on a Raster 1 image after the background has been erased
via the eraser tool.
The image is 32% ........( 32% of what ?)
Please help ...................................Ken
This has me stumped, I can not replicate your problem with the suntan or blemish brushes...
The image is 32% of its size. It's not being displayed at the 100% size.
Tim Morrison
Moderator
motherboard: Asus P4533
processor: 3.16 GHz
ram: 2GB
Video Card: Radeon HD4650
Hard_Drive_Capacity: 2.6 TB
Monitor/Display Make & Model: HP LP2275W
Post by Tim Morrison »
Don't select the Blemish Fixer, leave it in Suntan mode.
Tim Morrison
C-Tech Volunteer
Ken Veal
ram: 32 GB
strength of suntan
Post by Ken Veal »
got the suntan to work with another image but how do you increase the
strength of the suntan . PSPro X ........................Ken
Tim Morrison
Moderator
processor: 3.16 GHz
ram: 2GB
The Makeover tool is actually three separate tools in one. The Strength setting is not available for the Suntan tool, only for the other two... the Blemish Fixer and the Toothbrush tool.
As you've found, you can't go back over the Suntan tool a second time to increase the effect. That's a good thing, because otherwise the overlaps between brush strokes would show up. You need to do something like close and reopen the image, or duplicate it (Window > Duplicate or Shift + D) to be able to apply a second coat.
The best way would be to duplicate the layer (Layers > Duplicate) after going over it the first time. Then apply the Suntan tool a second time. This second application will only take place on the duplicated layer. The advantage of this is that if you find the second application is too strong, you can reduce the opacity of the top layer in the Layers palette. This will give you a range of suntans anywhere between a single application and a double dose.
A similar procedure can be used if you find a single application is too much. Duplicate the original, untanned layer, add the suntan to the duplicate layer, and reduce it's opacity to suit.
It can also be used if two applications isn't enough... do Layers > Duplicate again, which will now duplicate the layer with two doses of suntan, and apply a third coat.
Tim Morrison
C-Tech Volunteer
