Hello etech6355,
Thanks for your trial to help me out, but ..... still a mystery what really happens!
In the meantime I did a lot of trials and proofs and I want to report it here, maybe it could help other users or maybe somebody can help me who knows?
- my burner is a LG GGW-H20L
- I burned three video's perfectly on blue-ray BD-RE from LG and SONY
- new project (the fourth) and I burned this one perfect on a DVD
- but when I try to finish in HD blue-ray after rendering the program say "can not burn and error code 534:-2147216291:0 "
- I bought new BD-RE from PLATINUM and PHILIPS
- same result, same error code
- I googled on this number 534:-2147216291:0 and got some ideas but nothing helps
- In my opinion it cannot be a 'Defect Management' because otherwise it did not burn the first three times
- I wrote a fax message to LG in the Netherlands with the whole explanation: no answer after two reminders (very bad thing I think: once LG has sold the hardware they give apparently 'nobody home'!) I asked in this fax message if it could be a problem within the firmware. But personally I doubt if it can! Bu f ourse so long as I dont ave an answr from LG I don't know exactly if yes or no!
- I installed (with the repair tool) the Ulead VS 11.5 again, still no result
- again I burned a DVD of the same project only as trial: perfect, it works
- but again same error code when I try the blue-ray burning
- I was afraid that there maybe some adjustments were changed by myself within the program so I made new little projects with only a view scenes and took the original TOD files which I used in the first three projects (which one were perfect) - no result, it dosn't work, same error code
- so finally and in this very moment I am at the very end of the road and quite desperate: in the possession of a strong and fast PC, a perfect LG burner, good qualities of BD-RE's, a perfect software, three projects on blue-ray discs ...... and now nothing!
HELP, HELP, HELP - who outside and somewhere in this wonderful world has any experience with this problem (or maybe has the same problem) and is ready to discuss with me and look for solutions?
Videorolf
