VS Pro X2 - Import Digital Media crash
Has anyone been able to capture/extract video from a DVD-R in VideoStudio Pro X2?
Steps to reproduce:
1. Open VS Pro X2
2. Go into the Editor
3. Click on "1 Capture"
4. Click on "Import Digital Media"
Right after clicking on "Import Digital Media", I get the crash message:
"Corel VideoStudio encountered a problem and needs to close. We are sorry for the inconvenience..."
This happens every time in X2. 11.5 worked fine.
Steps to reproduce:
1. Open VS Pro X2
OS: Windows XP SP3
Mobo: ASUS M2N32-SLI Deluxe
Graphics: EVGA Nvidia GeForce 7950 GT
Sound: SoundMAX Integrated Digital HD Audio
CPU: AMD Athlon 64 FX-62 Dual Core (2.8 GHz)
HDD: SATA Maxtor 7H500F0 342GB free
RAM: 4.0 GB
RAM: 4.0 GB
FWIW, I just opened my X2, having already inserted a non-copyright DVD in the drive. I followed your work flow. As it does in VS11.5+, I got a screen asking if I wanted to import from folder or just Import. I selected the latter. A new screen appears saying it is parsing the contents of the disc. After that I get the usual directory tree of the DVD allowing me to choose what I want.
I also used my method (which is just to right click in the library window or timeline, and select 'Insert Digitial Media') and it did exactly the same thing.
So unfortunately, I am unable to to reproduce your problem.
Have you updated your DirectX recently? If not, see the top sticky post on this Board.
Yes, I installed the DirectX 9.x November release.
Looks like I solved the problem...
1. VS 11.5 Ultimate was already installed
2. Installed VS Pro X2
3. Uninstalled 11.5
--> "Import Digital Media" crashes in X2
4. Re-installed 11.5
--> "Import DVD" in 11.5 does not crash but does not provide a list of DVD Drives to choose from
--> "Import Digital Media" in X2 does not crash but does not provide a list of DVD Drives to choose from
5. Uninstalled 11.5
6. Uninstalled X2 (no VS installed on the system)
7. Did a clean install of VS Pro X2 without any other versions of VS
--> "Import Digital Media" works as intended
So for me, I had to completely remove VideoStudio (all versions) prior to installing X2 to make the "Import Digital Media" function work.
I have not and will not test to see if X2's digital media import still works if VS 11.5 is installed.
3. Uninstalled 11.5
5. Uninstalled 11.5
Zippy
..I too have multiple versions installed... 11.5+ and X2. When I installed X2, I was 1/2 expecting it to upgrade, rather than do a parallel install. In general X2 seems to behave pretty well for me (there's the exception of the automusic issue I posted earlier today).
The only issue I had with the import was that, for whatever reason (and mentioned in another thread), the import dialogue only displayed some of the available clips! I found, however, that I could just drag-n-drop the .MTS files direct into the library, and I was away
Zippy!
Zippy!
"The world is a book. Those who do not travel read only one page". Saint Augustine.
http://www.WinsterCavers.org.uk
hdspringer98
I have the same problem, install x2 pro with 11.5 active then uninstalled 11.5 and as soon as I click on capture video files it crashes. I will try uninstalling the entire thing, run cc cleaner and then start over with x2 and hope it works.
I would have preferred that x2 pro simply upgraded 11.5 and left my library in tact rather than have 2 instances of VS on the machine but that's just me.
They've always been stand alone installs, at least since my version 6.
If you have custom libraries simply copy them (to say, your desktop) then paste them into the appropriate folders in the new version.
Jeff
Dentler's Dog Training, LLC
- ram: 2 GB
- sound_card: Intel GMA 950
Please view:
Fix: Import DVD (VOB) Files DMF/VS/MSP
hdspringer98
Well everything is working fine now
removed 11.5,
ran cc cleaner,
uninstalled x2,
ran cc cleaner,
reinstalled x2.
I didn't have a custom library in 11.5 but I had a boatload of clips stored in the basic library that I now have to reload. At least I was able to open prior 11.5 projects without issue!
Successfully created, uploaded a clip to YouTube, started with an AVHD file, edited, shared to YouTube. Worked great. Just need to test an AVCHD burn with x2.
removed 11.5,
ran cc cleaner,
uninstalled x2,
ran cc cleaner,
reinstalled x2.
