Hi Guys,
I hope someone can help me. I am trying to import files to MF6 and I keep getting AVI is not accessable errors. I dont know what i am doing wrong? Just finding things a bit over whelming!!!
AVI problems
woolfie
- motherboard: Dell Inc. 0T568R A00
- ram: 6GB
- Video Card: NVIDIA GeForce GTS 240 1GB
- sound_card: Intel Display audio
- Hard_Drive_Capacity: 2TB
AVI problems
Sony HDR SR11E
avi (audio video interleave) is a wrapper, not a file format in itself. Wikipedia-AVI.
Can you provide the properties of these "avi" files? Where did they come from?
woolfie
- ram: 6GB
That doesn't really answer what type of file format is being used. For example are you aware that a WMV file can also be wrapped in AVI ? WMV is a highly compressed format, that is meant for distribution, not editing. Also your WMV files will have to be recoded to MPEG-2, so they can be burned onto a DVD. Unless you're making a data-dvd.
It could be that Sony outputs a Type-2 DV (avi), and MF is having problems with that. For DV, Type-1 generally provides less problems.
- ram: 2 GB
- sound_card: Intel GMA 950
Sorry but that doesn't help much.You wrote:....It's an AVI file ......
There are a small handful of file extensions that describe that a computer file is a video. These include
avi, mpeg, mov, rm, wmv, qt, swf
Plus a few others.
Think of these as groups of of a certain form of video, within those groups are lots of individuals. Liken this to animals, there are dogs, cats, snakes, birds, rodents and so on.
Within these groups are several types. For instance a dog can be a Poodle, Jack Russell, Alsatian, King Charles, Greyhound etc.
The term avi can mean any one of perhaps a hundred different types such as DV, MPEG4, uncompressed, MJPEG, DivX, Xvid, RLE, YUV, Cinepak and lots more.
You need to be more specific.
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
Apparently there are over 800 different avi file types!!!!!sjj1805 wrote:The term avi can mean any one of perhaps a hundred different types such as DV, MPEG4, uncompressed, MJPEG, DivX, Xvid, RLE, YUV, Cinepak and lots more.
You can use avicodec to find out what it is,
http://www.myvideoproblems.com/Tutorials/avicodec.html
Possible help with AVI problems in Vista
I was also having that problem (in Vista) and solved it by installing the update files using the "run as administrator" option. (right click the setup or install file and choose "run as admnistrator". It must have something to do with Vista's security layers. The program would import the avi files when first installed and not updated, but as soon as I applied the update files, it stopped working. You could also try just runnning the program with the "run as administrator" option to see if that helps, assuming you are running Vista.
I think I may be having the same problem with MovieFactory. Every time I try to open an AVI file I get the mesage 'unable to open file." Here is the information given by AVIcodec: Under the V. codec name tab it says "DivXNetworks Divx v5"; under the A.1 codec name tab it says "Mpeg-1 audio layer 3 (MP3)"; under the F. Info tab it says "VirtualDubMod 1.5.10.1 (build 2366/release)." This info is the same for all of the AVI files I have tried to open.
Ty converting your file to MPEG-2 (MPEG II) with SUPER (FREE!!!). If you're making a standard DVD, you'll need MPEG-2 anyway. If you're making a DivX disc, you'll have to let Movie Factory convert it back.
Whenever you convert from one lossy format to another, you'll get some quality loss. A higher bitrate will minimize the quality loss (and a higher bitrate will give you bigger files).
With MPEG-2 video, SUPER allows you the choice of MP2 or AC3 audio. (AC3 is generally better for DVDs. MP2 is non-standard for for NTSC DVDs.)
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
