I successfully created an HDV mpg2 for my HDV video project in VS11.5+. Initially, I had ghosting problems on panned white objects such as clouds with the VS11.5+ encoder which finally disappeared when I went to 30Mbps bit rate. The same problem cropped up when I then tried to create a DVD from this HDV mpg2. I tried to max out the DVD bit rate at 9800Kbps but could not get rid of the bad ghosting. I decided to use the TMPGEnc encoder (Video Encoder Express 3.1) which worked quite well. Then I brought the TMPEnc encoded DVD mpg2 file into VS11.5+ for DVD authoring. Unfortunately, VS11.5+ could not recognize any audio in the file. I know there is audio in the file because I was able to play back the file in VLC Media Player and also created a DVD with Nero Express and both times I had audio. Since Nero Express does not have as many features for DVD Authoring as VS11.5+, I would like to use VS11.5+ for creating my DVD. But I cannot get VS11.5+ to read the audio in the file. The closest similar board post is at http://phpbb.ulead.com.tw/EN/viewtopic. ... ht=tmpgenc . But I did not find a solution to this loss of audio in VS11.5+ in the post.
Here are the stats of the DVD mpg2 from mediainfo.exe:
General #0
Complete name : C:\My Video\StLucia071201\StLucia071201g_full8MUFF384x50qKeepIntSharp100W.mpg
Format : MPEG-2 Program
Format/Family : MPEG-2
File size : 2.91 GiB
PlayTime : 49mn 2s
Bit rate : 8495 Kbps
Writing library : encoded by Video Encoder XPress Version. 3.1.5.80
Video #0
Codec : MPEG-2 Video
Codec/Family : MPEG-V
Codec profile : Main@Main
Codec settings, Matrix : Standard
PlayTime : 49mn 2s
Bit rate mode : CBR
Bit rate : 7521 Kbps
Nominal bit rate : 8000 Kbps
Width : 720 pixels
Height : 480 pixels
Display Aspect ratio : 16/9
Frame rate : 29.970 fps
Standard : NTSC
Chroma : 4:2:0
Interlacement : Top Field First
Bits/(Pixel*Frame) : 0.772
Audio #0
Codec : MPEG-1 Audio layer 2
PlayTime : 49mn 2s
Bit rate mode : CBR
Bit rate : 384 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
No audio from TMPGENC mpg2
I don't know what the problem is, but here's something you can try....
Try making a separate audio file from the original HD file. Go to Share and create an audio file. (Make a 48kHz, 16-bit WAV... The least-compressed audio/video cause the least trouble!)
Then, use that WAV file along with the TMPGEnc video file to make the DVD.
(The MPEG-1 Audio layer 2 format that you're getting from TMPGEnc is not valid for your NTSC DVD. You need AC3 or LPCM audio... But, Video Studio should be able to decode and convert it.)
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
