avi files
wstagner
motherboard: Gigabyte Ga-p43-es3g
processor: Intel Core 2 Quad Q8400 2.66 GHz
ram: 8gb
Video Card: ATI Radion HD4300 4500 series
sound_card: ATI High Definition Realtek ALC888 codec
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Asus VH242H 24" 1920x1024 screen.
avi files
Post by wstagner »
Apparently VS 10 captures/edits files as AVI.
From what I see in VS 11.5, AVI is not even listed as a supported file format.
Is there any way to edit and/or create a DVD in VS 11 with this apparently obsolete files?
If there's aleady a thread about this please direct me to it.
TIA
Walt
Accolades
motherboard: Gigabyte GA-EX58-UD4
processor: QuadCore Intel Core i7 920 2833 MHz 21 x 135
ram: 12 GB DDR3
Video Card: Nvidia GeForce GTX 295
sound_card: On Board 5.1 Surround - Realtek ALC888 - 1200
Hard_Drive_Capacity: 4TB +
Post by Accolades »
VS X2 is out !!
Their are over 100 types of files in the "AVI" format
GOOGLE AVI FORMAT!
My You Tube Channel:
My Vimeo Channel:
SONY MOVIE STUDIO PLATINUM HD 10, Corel Video Studio X3, Corel Draw Graphics Suite X4 (Draw, Paint), Adobe Photo Shop CS4, Adobe Bridge CS4, DivX 8, Irfranview, FRAPS, Deamon Tools, VLC, MyDefrag, Nero, AVG, Winamp, Autopano, VMware...
wstagner
ram: 8gb
Post by wstagner »
Thanks, but this doesn't help me. I purchased 11.5 because I didn't like the "black" interface that it didn't look like was changeable.
Plus from what I read on this forum, didn't look like very many were happy w/it.
Accolades
ram: 12 GB DDR3
Post by Accolades »
DV Data in the AVI File Format
Microsoft DirectShow 9.0
Microsoft has specified the format for storage of digital video (DV) data in AVI files. Conforming to this specification will ensure that the AVI files authored in this format will be compatible with future versions of the MicrosoftR DirectShowR digital video architecture for the MicrosoftR WindowsR platform.
This article describes the format of AVI files containing DV data. Specific FOURCCs (four-character codes) for interleaved DV data streams and DV compressor/decompressor stream handlers are defined. The stream format structure for DV data is defined. Specifications for two methods of storing DV data in the AVI file format are specified.
It is assumed that the reader is familiar with the DV data format. (This format is defined in the Specification of Consumer-use Digital VCRs, also called the Blue Book).
There are two types of DV AVI files: AVI files that contain one DV data stream, called type-1 files; and AVI files that contain DV video as a 'vids' stream and DV audio as 'auds' streams, called type-2 files.
AVI Files Containing One DV Data Stream (Type-1)
Interleaved DV data can be stored in its native format as a single stream within an AVI RIFF file. This has the advantage of using the minimum amount of data storage for DV. The primary disadvantage is that this file format is not backward-compatible with Video for Windows, because it doesn't contain either a video 'vids' or an audio 'auds' stream. Support is provided for the interleaved DV stream through the DV Muxer and DV Splitter filters provided with DirectShow.
DV data can be stored in a single stream within an AVI RIFF file by specifying the 'iavs' (interleaved audio and video stream) FOURCC (four-character code) in the fccType member and either of the 'dvsd', 'dvhd', or 'dvsl' FOURCCs in the fccHandler member of the 'strh' stream header chunk. The frames per second of the video stream must be specified in the dwRate and dwScale members and the total number of video blocks in the 'movi' chunk in the dwLength member.
The 'dvsd' stream handler FOURCC specifies that the DV data is as defined in Part 2 of the Specification of Consumer-use Digital VCRs. Video is in the format of 525 lines at 29.97 Hz (525-60) or 625 lines at 25.00 Hz (625-50).
The 'dvhd' stream handler FOURCC specifies that the DV data is as defined in Part 3 of the Specification of Consumer-use Digital VCRs. Video is in the format of 1125 lines at 30.00 Hz (1125-60) or 1250 lines at 25.00 Hz (1250-50).
The 'dvsl' stream handler FOURCC specifies that the DV data is as defined in Part 6 of Specification of Consumer-use Digital VCRs. Video is in the format of high-compression SD (SDL).
Note The remainder of this article provides definitions for 'dvsd' streams.
The stream header chunk must be followed by a DVINFO stream format chunk.
The actual DV data is stored as '##dc' chunks in the 'movi' chunk (the ## in the format represents the stream identifier). Each chunk contains one frame of data, either 10 or 12 DV DIF sequences for 525-60 or 625-50 systems, respectively. The DV SD ('dvsd') DIF sequence format is defined in Part 2 of the Specification of Consumer-use Digital VCRs.
The following example shows the AIFF RIFF form for an AVI file with one DV data stream, expanded with completed header chunks.
00000000 RIFF (0FAE35D4) 'AVI '
0000000C LIST (00000106) 'hdrl'
00000018 avih (00000038)
dwMicroSecPerFrame : 33367
dwMaxBytesPerSec : 3728000
dwPaddingGranularity : 0
dwFlags : 0x810 HASINDEX | TRUSTCKTYPE
dwTotalFrames : 2192
dwInitialFrames : 0
dwStreams : 1
dwSuggestedBufferSize : 120000
dwWidth : 720
dwHeight : 480
dwReserved : 0x0
00000058 LIST (0000006C) 'strl'
00000064 strh (00000038)
fccType : 'iavs'
fccHandler : 'dvsd'
dwFlags : 0x0
wPriority : 0
wLanguage : 0x0 undefined
dwInitialFrames : 0
dwScale : 100 (29.970 Frames/Sec)
dwRate : 2997
dwStart : 0
dwLength : 2192
dwQuality : 0
dwSampleSize : 0
rcFrame : 0,0,720,480
000000A4 strf (00000020)
dwDVAAuxSrc : 0x........
dwDVAAuxCtl : 0x........
dwDVAAuxSrc1 : 0x........
dwDVAAuxCtl1 : 0x........
dwDVVAuxSrc : 0x........
dwDVVAuxCtl : 0x........
dwDVReserved[2] : 0,0
000000CC LIST (0FADAC00) 'movi'
0FADACD4 idx1 (00008900)
AVI Files Containing DV Video and DV Audio Streams (Type-2)
Interleaved DV data can be split into a video stream and one to four audio streams within an AVI RIFF file. This has the advantage of being backward-compatible with Video for Windows, because it contains a standard video 'vids' stream and at least one standard audio 'auds' stream The primary disadvantage is that this file format requires the audio data to be redundantly stored as audio streams. The "video" stream is actually the native interleaved DV data stream. However, as a standard 'vids' stream with a handler type of 'dvsd', the DV Video Decoder is used. This format also requires using the DV Splitter filter to split "captured" files before writing them as AVI files.
DV data can be stored as a video stream with a separate number of audio streams in an AVI RIFF file. The video stream is specified with a standard video stream header (the fccType member value is 'vids'). The fccHandler member is specified as 'dvsd', 'dvhd', or 'dvsl'. The frames per second of the video stream must be specified in the dwRate and dwScale members and the total number of video blocks in the 'movi' chunk in the dwLength member.
In this AVI file containing DV video as a 'vids' stream and DV audio as 'auds' streams form of DV, the video stream format chunk is a standard BITMAPINFOHEADER structure. The stream format chunk can be optionally extended to include the DVINFO chunk, by increasing the stream format chunk size from 40 bytes (size of the BITMAPINFOHEADER structure) to 72 bytes (size of BITMAPINFOHEADER plus DVINFO structures) and immediately following the BITMAPINFOHEADER data structure with a DVINFO data structure.
The audio stream(s) is specified with a standard audio stream header (the fccType member value is 'auds'). The fccHandler member is not used for audio streams.
The DV video data is stored as '##dc' chunks, as defined in the preceding description of an AVI file with one DV data, and the audio data is stored as '##wb' chunks in the 'movi' chunk.
The following example shows the AIFF RIFF form for an AVI file containing DV video as a 'vids' stream and DV audio as 'auds' streams expanded with completed header chunks (including optional DVINFO data following the BITMAPINFO in the 'strf' sub-chunk for the 'vids' stream).
00000000 RIFF (103E2920) 'AVI '
0000000C LIST (00000146) 'hdrl'
dwInitialFrames : 0
dwStreams : 2
dwWidth : 720
dwHeight : 480
dwReserved : 0x0
00000058 LIST (00000094) 'strl'
fccType : 'vids'
fccHandler : 'dvsd'
dwFlags : 0x0
wPriority : 0
dwInitialFrames : 0
dwRate : 2997
dwStart : 0
dwLength : 2192
dwQuality : 0
dwSampleSize : 0
000000A4 strf (00000048)
biSize : 40
biWidth : 720
biHeight : 480
biPlanes : 1
biBitCount : 24
biCompression : 0x64737664 'dvsd'
biSizeImage : 120000
biXPelsPerMeter : 0
biYPelsPerMeter : 0
biClrUsed : 0
biClrImportant : 0
000000F4 LIST (0000005E) 'strl'
00000100 strh (00000038)
fccType : 'auds'
fccHandler : ' '
dwFlags : 0x0
wPriority : 0
dwInitialFrames : 0
dwScale : 1 (32000.000 Samples/Sec)
dwRate : 32000
dwStart : 0
dwLength : 2340474
dwSuggestedBufferSize : 4272
dwQuality : 0
dwSampleSize : 4
rcFrame : 0,0,0,0
00000140 strf (00000012)
wFormatTag : 1 PCM
nChannels : 2
nSamplesPerSec : 32000
nAvgBytesPerSec : 128000
nBlockAlign : 4
wBitsPerSample : 16
cbSize : 0
00000814 LIST (103D0EF4) 'movi'
103D1710 idx1 (00011210)
My Vimeo Channel:
wstagner
ram: 8gb
Post by wstagner »
Dunno why you posted all this technical stuff.
All I want to know is can I SOMEHOW use my VS10 avi video files in VS11.5?
Accolades
ram: 12 GB DDR3
Post by Accolades »
YES
My Vimeo Channel:
wstagner
ram: 8gb
Post by wstagner »
How?
Accolades
ram: 12 GB DDR3
Post by Accolades »
Now that would mean posting technical stuff !! :-)
My Vimeo Channel:
Accolades
ram: 12 GB DDR3
Post by Accolades »
Before asking questions in this forum, have you checked everything in the USER MANUAL and Readme of the program?
Also, please look in the Corel Knowledge Base. Then use Search because someone may have already asked the same question.
If you have not already done so, click on Profile in the forum header and fill in the fields titled:
Operating System:
Motherboard:
Graphic Card:
Sound Card:
Processor:
Hard Disk Drive:
Memory:
For problems not covered, please use this copyable format in posting your questions:
SUBJECT: Please use a subject that describes your exact problem
Describe your problem:
Properties of your source files (format, file size, where did you get it?):
What devices are involved and their mode of connection?:
Project Properties (important):
Output format (file, DVD, VCD, SVCD):
PAL or NTSC:
Error Codes (if any):
Product Version: e.g. VS10 or VS11+
By following these simple rules, you will increase your chances of obtaining a solution to your problem.
Thank you
My Vimeo Channel:
There are over 800 different video formats which use the .avi extension. It is by no means obsolete but very alive and very well. The DV format Accolades mentioned is just one of them.
Raw, uncompressed AVI is huge -- around 65 GB per hour of video. DV/AVI is more compressed, but still large at 13 GB per hour. At the other end of the spectrum are highly compressed formats such as DivX and XVido, which are really similar to mpeg-4 video, but still use the .AVI extension. For those the necessary codecs must also be installed on your computer.
Now, depending on which type of AVI you are talking about, it is imported into VS11/.11.5+ the same way you import them into VS 10. You right click in either the timeline or in the library window and choose Insert Video. You navigate to where you AVI files are stored and select those you want in a project. Click Open, and then proceed as you have with VS10.
Accolades
ram: 12 GB DDR3
Post by Accolades »
Ken Berry wrote:There are over 800 different video formats which use the .avi extension. It is by no means obsolete but very alive and very well. The DV format Accolades mentioned is just one of them.
I wonder why so many ???
My Vimeo Channel:
It's a bit like audio where .wav is the rock standard basic audio format and all the others are newcomers, so to speak. AVI was one of the original video formats, and later variations simply tacked themselves on for a wide variety (say 800) of reasons, but mostly because it was easily recognised. In that sense, AVI really only is a wrapper extension...
wstagner
ram: 8gb
Post by wstagner »
In VS11.5, if I click on the folder icon (load video) a window opens in the folder with my files (edited w/vs10). Unless I choose a TYPE of all files, files with AVI extension are not an option.
With "all files", I can see my vs10 files and if I try to open one I get:
"file format mismatch"
They'll open in VS10 just fine.
If you still have VS10 installed, insert one of those "avi" files into the library or timeline. Then right-click on it, select properties and post them back here. That way we might be able to see why you are getting that error.
wstagner
ram: 8gb
Post by wstagner »
Ok
