I've just tried latest PowerDirector7, build 2206. It looks that their SVRT (smart render) works OKPrzemek wrote:I've just spoken to Corel customer support. All thay could tell me was that there must be something wrong with the avchd codec used by my camera - HF100, and since this camera is not supported by COREL X2, I need to buy different software
Distortion after Transitions-Power Director 7
michal_h
- motherboard: -----
- processor: Core i5 520M
- ram: 8GB DDR3
- Video Card: GeForce GT 330M 1 GB GDDR3
- sound_card: -----
- Hard_Drive_Capacity: 120 GB SSD
canon hf100
corel VS pro x3
corel VS pro x3
michal_h
- ram: 8GB DDR3
- sound_card: -----
yes smart render doesn't work properly in trial you need full version...Efenstor wrote:Yes, PowerDirector 7 really does the job, but there are negative sides (at least in the trial version) I've noticed: it always recompresses video despite of the praised "smart" mode and there's no way to set the output bitrate.
canon hf100
corel VS pro x3
corel VS pro x3
I tried PowerDirector 7 in late August before buying Pro X2 and found that AVCHD hybrid discs had bad pixalization in areas of small detail, such as grass, when the camera moved, even the slight movement caused by hand-holding the camcorder but not panning or zooming. The same source clips rendered by Pro X2 did not have this problem.
Has anyone found that newer versions of PD7 have solved this problem?
It was exactly because you TRIED, smart render doesn't work as should in the trial version and pixelization was caused by re-encoding to a lower bitrate (as I remember it's about ~13000 kbps and cannot be changed). I've just bought PowerDirector 7 Ultra and now downloading it, once it's done I'll give it some tests and write back does it really do the job without pixelizations and other bad things.dalemccl wrote:I tried PowerDirector 7
Yes, it was the trial version (v.1820 if I recall correctly). I'll look forward to the results of your tests with the latest purchased version.Efenstor wrote:I'll give it some tests and write back does it really do the job without pixelizations and other bad things.
If re-encoding in PD7 causes the pixalization problem, that would concern me because there are situations I have encountered where re-encoding is necessary, for example, when applying lighting/color correction to clips.
Sektionschef
michal_h
- ram: 8GB DDR3
- sound_card: -----
no sony vegas pro dosn't smart render for canon hf100 maybe only for sony's camcordersSektionschef wrote:According to other users Sony Vegas Pro also supports smartrendering and should work fine too.Efenstor wrote:Looks like it's the only solution yet for those who have the distortion problem.
Regards
Sektionschef
canon hf100
corel VS pro x3
corel VS pro x3
michal_h
- ram: 8GB DDR3
- sound_card: -----
I made only small test with PD7 but if I insert two clips on the timeline one transition and start creating file using SVRT it looks like SVRT works only for the first clip (fast rendering), the transition is rendered slower as I expected but the second clip is rendered with the same speed as transition - it should be rendered with the same speed as first clip. Could you confirm it?Efenstor wrote:It was exactly because you TRIED, smart render doesn't work as should in the trial version and pixelization was caused by re-encoding to a lower bitrate (as I remember it's about ~13000 kbps and cannot be changed). I've just bought PowerDirector 7 Ultra and now downloading it, once it's done I'll give it some tests and write back does it really do the job without pixelizations and other bad things.dalemccl wrote:I tried PowerDirector 7
canon hf100
corel VS pro x3
corel VS pro x3
