VHS CAPTURE PROBLEM WITH S-VIDEO CONNECTION
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
Royde wrote:Ken
Just to clarify a point
With scart involved I can capture with s-video without any trouble - but it is black and white?
Roy
That is because either the vhs player is not an s-video player, the cables concerned are not s-video or the input to the pc is not s-video.
And as you said your vhs player does not have an s-video connector on it, I must say it isn't an s-video vhs player, so you will always get black and white due to the different way composite and s-video carry the colour signal.
Mind you if you feel capturing in black and white is without any trouble, we're sorted :D
skier-hughes
Microsoft MVP
ram: 4GB
sound_card: onboard
Re: Who can capture S-Video in colour
trevor andrew wrote:Hi Roy
I believe I have a similar problem in capturing S-video in B/K
Only capturing using composite provides colour.
I own a Samsung Pal Combo DVD/VHS player which has S-Video Out socket.
I also have a scart-plug with S-Video connection
Either option produces B/K
I have tried many/many options over as many years but still get B/K
It would be nice to capture in colour just to compare the quality.
My question is:-
Who on the forum can capture using S-Video and achieve colour :?: :?: :?:
Are the tapes you are trying to capture from recorded using s-video?
What is the exact model of the player?
What are you plugging the cable into, exact make and model of capture device?
I can, I use a Sony svhs player, with s-video leads into a canopus break out box connected to a canopus nx capture card and edius 4.61.
Post by Trevor Andrew »
Hi Graham
Thanks for the reply, sorry for the lack of detail, I should know better.
The Samsung Combo is a :-
DVD/VCR DUEL DECK
Model:-
SV-DVD1EA
Capture Card using Ati All in Wonder 128 Pro Graphics Card.
The tapes being used (and I have tried several) have not been recorded using S-Video
First of all the Player has not been used for a few years, only to be powered up to assist the OP. My thought was if I can fix mine then I can help others. Problems with S-Video force me to use composite for my analogue capture. That is other than using a camcorders pass through option.
Ok
I have an S-Video socket, this appears to output the DVD player only and is ok in colour.
Using a Scart with S-Video connection I can see Colour for the DVD but B/K for the VHS.
You commented on tapes being recorded using S-Video.
Are you saying that the tapes have to be S-Video?
PidTel
motherboard: MSI K9N SLI Platinum
processor: AMD Athlon 64 X2 4600
ram: 3GB
Video Card: 7600GT
sound_card: on motherboard
Hard_Drive_Capacity: 1460GB
Post by PidTel »
That indicates there is only a composite video output from the VHS player. Does the user manual say anything about s-video on VHS playback? It was not normally included on VHS machines but since the s-video facility already exists for the DVD player it would have been quite simple to implement.
Whether the tapes were recorded from a composite or s-video source is irrelevant.
Tom
Hi Tom
Thanks for that, when the player was put in storage so was the manual, unfortunately that¡¦s still in storage, but from what I remember the info on input/output sources was a little lacking.
Since my last post I connected the player to an aerial input, Was able to view some channels in colour some in B/K. So assumed this to be a signal strength problem.
If that¡¦s the case then why the VHS tape problem.
(Hamilton in Brazil winning the racing viewed great, but using composite.)
Would it be better in s-video
I¡¦m not sure it would.
The more I play about the more I think the player is at fault
skier-hughes
Microsoft MVP
ram: 4GB
sound_card: onboard
trevor andrew wrote:Hi Graham
DVD/VCR DUEL DECK
Model:-
SV-DVD1EA
Ok
http://downloadcenter.samsung.com/conte ... XSA-GB.pdf
Odd, the manual makes reference to s-vhs on the remote, but does state that the s-video port is dvd only.
The Ati card is said to have s-video in and out.
To get the best from s-video, you need to have an s-video recorded tape, otherwise you are just showing a composite recording via an s-video cable. Record a vhs to dvd and it doesn't get better.
Remembe s-video is just video, oit doesn't carry an audio signal so you need to connect an audio cable from the decks output to the sound cards input.
Hi Graham
Thanks for the link to the user manual, the original manual will turn up some time, probably when I don¡¦t need it.
The S-Video port being dedicated to DVD only doesn¡¦t really make sense, I would have thought it should output the VHS player as well.
Anyway the more I look at it, the more convinced I am that there is a fault with the unit.
Maybe its time to get the screw-drivers out, I¡¦ll let you know if I have any bits over.
And now I understand your comments regarding S-Video quality.
Thanks again
skier-hughes
Microsoft MVP
ram: 4GB
sound_card: onboard
s-video is a way of carrying colour/chrominance/luminance it has nothing specific to do with vhs, so it is understnadable that the dvd part of the machine can be s-video capable but that the vhs part of the machine is not.
PidTel
ram: 3GB
Video Card: 7600GT
Post by PidTel »
VHS (and S-VHS) recorders separate a composite video source into luminance and chrominance before recording and re-combine them into composite on playback, so it is quite simple to implement s-video inputs and outputs.
Tom
skier-hughes
Microsoft MVP
ram: 4GB
sound_card: onboard
True, but my point was that it s-video is not directly related to vhs
