Does Corelvs12 pro have issues with vista?
Folks I have been trying to use my Toshiba laptop A215-S6816 with Vista home prem, a JCV GR-D270 camcorder to capture video to file but the program will only capture a few seconds of video and then stop. The program controls the camera but it just will not capture video. Any suggestions please. Comp 2gb ram bus speed 533 lots of space. Firewire connected.
- ram: 2 GB
- sound_card: Intel GMA 950
Please try the following patch.
ftp://ULMPG29G:PEYEPK69@Private.ulead.c ... OPATCH.exe
Thank you for your quick response
I have downloaded and applied the patch. The same problem persist. I have since reemoved and reinstalled VS12 pro and patch. Still only few seconds recording. Capture device keeps switvhing between built in cam corder and DV compliant device (DV camera). Could it be that a JVC driver is needed. Site not very helpful. The camera works on another machine under XP Pro. Thank for any help or suggestions
- ram: 2 GB
RD has given me another build for you to test.
Please download the "IviAvCtl.dll" file from here:
http://www.humyo.com/F/6113409-204875689
Then
ftp://UL9MYQD6:6D1W8BNY@Private.ulead.c ... 812-14.zip
Try the following steps:
1. Use the attachment to replace the file of IviAvCtl.dll in UVS 12 AVControl folder to check if work
2. Send the test tool \\ks-nas\Testdata_KS\UDC\1.0\UDC1.0_(E)_for UVS\0812-14 to the user
Then
Did VS work ok with the camcorder previously with an XP pc?
No version of VS has ever satisfactorily controlled my own JVC camcorder. It always starts playing immediately after I click on the "capture" tab and I have to stop it with the camcorder controls - otherwise VS will leave it in a noisy paused state that sounds like the tape is oscillating. One time I left it in that state for a few minutes, and had to run a head cleaner afterwards. I believe it actually damages the camcorder. So I prefer start playback using my camcorder controls, after which I hit the "start capture" icon in VS. I then have VS set so as not to stop the camcorder when I hit "stop capture".
On the other hand, Intervideo WinDV Creator 2 controls the JVC perfectly, but often times I prefer to use a small freeware program called WinDV to capture my footage.
Thank you sjj1805
I have down loaded the first link but the second one is slow down loading.I will try all your seggestions and report back to the forum. For 2dogs, Yes I have used Vs from vs 10 and 11 on another comp running XP. VS 10 seem to be the most stable so far but vs 11 is working fine. I like the new features in VS12 if only I could get it to run on vista. Will report the result of all patches.
Accolades
- motherboard: Gigabyte GA-EX58-UD4
- processor: QuadCore Intel Core i7 920 2833 MHz 21 x 135
- ram: 12 GB DDR3
- Video Card: Nvidia GeForce GTX 295
- sound_card: On Board 5.1 Surround - Realtek ALC888 - 1200
- Hard_Drive_Capacity: 4TB +
Are these patches for ALL VISTA Installs ov VS X2 Pro?sjj1805 wrote:RD has given me another build for you to test.
Then
My You Tube Channel:
My Vimeo Channel:
SONY MOVIE STUDIO PLATINUM HD 10, Corel Video Studio X3, Corel Draw Graphics Suite X4 (Draw, Paint), Adobe Photo Shop CS4, Adobe Bridge CS4, DivX 8, Irfranview, FRAPS, Deamon Tools, VLC, MyDefrag, Nero, AVG, Winamp, Autopano, VMware...
My Vimeo Channel:
Finally tested all still no luck
sjj1805 I have tested all the patches you so kindly sent I guess I will have to give up on either VISTA or JVC. Thanks a lot.
