how to repair jerky clip stutters
meegwell
Post by meegwell »
I've read a lot about the source of jerky output but not tips to fix my situation, which is:
DV capture via firewire is fine, no stutters in source files. (VS 11+).
When I add clips and effects, stutters pop up and remain, in the same spots, through preview and rendered DV (avi) file.
PC specs are posted in profile but generally its a intel 1.6 w/ 2GB, 7200 100gb free.
I haven't tried turning off the mcafee and such but I'll get to that. My real question is, since the source file is fine, do I need to re-do from scratch each clip that has a stutter in it or is there some way for them to be "rebuilt" by VS?
The stutters are often in pan & zoom still photos but in video clips as well.
Properties of Project:
NTSC drop frame (29.97 fps)
MPEG files
24 bits, 720 x 480, 29.97 fps
Lower Field First
(DVD-NTSC), 16:9
LPCM Audio, 48000 Hz, Stereo
Thanks,
Mike
When creating your DV file, have you checked to make sure the field order is the same as that of your project settings? It may have been inadvertently set to Upper Field First.
Disabling your antivirus, instant messenger, and other non-essential services or programs is a good idea. That way you need not worry about one suddenly springing to life, interrupting things..
What you are trying to do, and the formats and properties you are using, are absolutely rock standard, and there is no obvious software-related reason why you should be getting stuttering. The only logical conclusion I can draw is that it is hardware-related. Your processor (1.6 GHz) is a bit on the light side, though I used regularly to convert DV to DVD-compliant mpeg-2 on an old 1 GHz computer, and users before that used even weaker processors with no problem.
However, VS11 is rather more demanding of computer resources than the earlier versions I was using on that older computer, and I used to disconnect from the internet, shut down my anti-virus and turn off as many background operations as possible. Any of these suddenly deciding to do something, or scan something else, would cause blips in the processing of the video.
So I can only agree with Vidoman that you should first turn off as many things as possible, and if necessary even develop a special video-only profile which you can log-on to when using VS.
DVDDoug
Moderator
Post by DVDDoug »
I have no idea what the problem is....
But your processor speed or programs running in the background should not cause glitches in the rendered file!
The editing/processing/rendering is all "number crunching" by the CPU. There are things that can slow-down the process, but nothing like that should generate errors or corrupt the data.
Of course, speed and interruptions can affect real-time operations, such as capture, playback and preview.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
On the old computer I mentioned above, which was in my pre-broadband days, if I received a phone call (same line as my dial-up modem but with a call-waiting facility), then my DV > mpeg-2 conversions most definitely suffered dropped frames at that point. Ditto if the anti-virus decided to scan something while the conversion was going on... So I am not absolutely certainly we can rule out hardware resources as being a cause in the current situation... :roll:
meegwell
Post by meegwell »
thanks all...I will first try a "lite" setup closing down all things unecessary and run a few tests. My pc has been running a bit slow lately and could use a tune up.
What about the repair? Do I need to re-do each clip from scratch or is there a was to let it re-calc given all the criteria it already has?
2Dogs
Post by 2Dogs »
From the hard drive info in your "system" info, I would have guessed that you had a desktop pc - but from the processor, do you actually have a laptop? If so, and if it's a dual core machine, you won't see any appreciable speed benefit from turning off unnecessary programs, services and processes - although it may still be a good idea to do so to minimise the risk of conflicts.
It might be worth you running chkdsk - from the hard drive properties, select "tools" > "error checking" and click on "check now". The test will require you to re-boot.
Then run disc cleanup and then run the defragmenter.
All of that may take a bit of time but will rule out some possible causes of your problems.
babdi
motherboard: ASRock Extreme 11
processor: Intel 3770K
ram: 32 GB DDR3
Video Card: Asus 660TI 2 GB
sound_card: On board Realtek
Hard_Drive_Capacity: 6.128 TB
Monitor/Display Make & Model: 22",BenQ 2222 LCD HD 1920x1080
Corel programs: Video studio
Post by babdi »
I am not sure if increasing windows SWAP size will help :-?
There is a light within a light and a shadow within a shadow. - Rembrandt
2Dogs
Post by 2Dogs »
babdi wrote:I am not sure if increasing windows SWAP size will help :-?
Interesting point, Babdi.
I always set my swap file to be a fixed size - otherwise Windows might decide to resize it, causing a delay in proceedings when it does so, but not necessarily any visible defects in rendered video. The general rule used to be to set the swap file to 2 x RAM, which in your case would be 4Gb - but to me that is excessive, and I might use 2Gb for both the swap file minimum and maximum sizes. It may not help, but it won't do any harm.
meegwell
Post by meegwell »
thanks again for great input. I have several of these clips so I was mainly wondering about about the repair? Do I need to re-do each clip from scratch or is there a was to let it re-calc given all the criteria it already has?
meegwell
Post by meegwell »
just bumping this question:
Post by Black Lab »
Not sure what you mean by "re-do each clip from scratch". If the captured clips are fine there is no need to re-capture. Have you tried re-rendering with excess apps turned off?
meegwell
Post by meegwell »
ahh, I think that is what I am trying to do. Re-render. I assume that is straight forward? Yes, the source clips are fine. Is there a process for re-rendering? Please excuse my ignorance.
Post by Black Lab »
Clip>Save Trimmed Video will render an edited clip to a new clip. Share>Create Video File will render your entire project to a new clip.
