vs x2 closes right away
chuckpie
Post by chuckpie »
My VS x2 splash screen opens, I click in editor, the new splash screen opens followed by the user interface, after a short time the program closes. What is the problem???
Post by Black Lab »
Do you do any capturing or editing at all?
chuckpie
I Can't
Post by chuckpie »
The program will not let me do anything. The program interface with the splash screen just close after about 10 to 15 seconds.
Post by Black Lab »
Do you have the trial version or did you purchase?
If purchased, was it the download or boxed version?
Have you tried to repair/reinstall?
chuckpie
Boxed
Post by chuckpie »
The version is a boxed upgrade. I have removed and reinstalled. The funny thing it worked the last time I used it and now I have this problem. I did the upgrade from version 11.5. Another thing is with version 12 installed version 11.5 does the same thing, however when I remove version 12 then version 11.5 works. Driving me nuts!! Thanks for anyone's help that may have had this problem!!
Post by Black Lab »
What happens if you remove both versions, then install only v12?
Another thing you can try, since it did work at one time, is a System Restore.
chuckpie
No Luck Jeff
Post by chuckpie »
I tried both of those solutions this morning with no success. I have VS 12 at work also, so I am going to poke around the common files and see if they match what I have at home. I plan to uninstall version 10 that is on my home computer and reinstall all versions to see if I have a corrupted file some where. The only software changes I have had is the automatic update from Microsoft. I guess it is possible that somehow over wrote something. I post the answer when I have one. Thanks Jeff
Try working your way through the following link:
Troubleshooting your computer
chuckpie
Still the same problem!!
Post by chuckpie »
I cannot believe I am the only one who has had this problem. It may indeed be a problem with my computer, however that does not explain why version 11.5 runs fine as long as I remove X2. Since X2 tries to start but closes after several seconds it seems it is looking for a missing file. The real strange part is I purchased a full boxed version because I thought the problem could be with my upgrade version, however the same problem. All my other programs run fine. Need Help Still!!!!!!! :x
You haven't told us anything about your computer or the operating system. But if it is Vista, try right clicking on the X2 icon, and choose 'run as administrator'... though I should note that this is only a wild guess as X2 should normally open ... well, normally! :cry:
