Question is, how does one go about doing that in DVD WS? When I pull down the menu for the burn speed, the only options I see are "MAX" and "8X," which are the same thing.
Specify burn speed?
videojanitor
Specify burn speed?
In another thread, I was advised to burn discs at a slower speed than specified by the media -- ie: burn 8X discs at 4X or slower for more robust data.
videojanitor
videojanitor
compare the differences
Don't forget to do a comparison between the DVD Workshop 2.0 FULL and EXPRESS versions (to see which version meets your needs)
http://www.ulead.com/dws/compare2.htm
George
videojanitor
George,
I most certainly checked out the comparions before buying. It was pretty clear that "Express" is good for me -- I don't need any capture plug-ins, DLT, Macrovision, CSS Encryption, Regional Coding, etc. etc. I'm just interested in the usability enhancements, like the ability to check chapter points in the "finish" mode, and set the burn speed -- nothing earth-shattering.
One thing I did notice with the trial version though is that I couldn't hear the AC-3 audio that was included with the MPEG file I imported -- I *assume* that's because the trial version does not support AC-3. Apparently not even for *listening* to files that were previously encoded. If I still can't hear it when I get the full version of Express, then we've got a problem!
--Bill
--Bill
I've no problem with AC-3 2/0, but it may be that the trial version does not have it implemented for licensing reasons. Dolby are not exactly known for giving away licences!
videojanitor
Devil,
Thanks for the info. On the download page for the trial version, one of the limitations listed is:
"No support for Dolby® Digital audio files"
I guess when they say "no support," they mean it -- you can't even listen to them. For what it's worth, version 1.0 didn't support it either, but I found you could enable it by editing one of the .ini files. At least then you could hear something as you were looking for chapter points. Later patches disabled this, so I always had to make sure I was running an un-patched version.
