Vignette removal
Rollason
- motherboard: Intel GM 45
- processor: Intel core i3 2 duo P8400 2.2GHz 1066 MHz 3MB
- ram: 3GB
- Video Card: 1GB ATI Mobility Radeon HD 5650 Graphics Card
- sound_card: JBL 2.1 + SRS Premium Sound
- Hard_Drive_Capacity: 320GB
Vignette removal
I have some clips where, zooming in with a polaroid filter in place, I vignetted the clips. I believe I read somewhere a method to, in effect, reduce the apparent size of the clip and thus trim the outside edges of the clip.
Can anybody give me further information on this or possibly direct me to a tutorial? I've checked through the forum but can't find anything that appears to offer a solution.
Many thanks.
Many thanks.
The Cropping Filter will remove the vignette but leave you with a black border.
Not much difference I suppose.
You could try the Distort function under the ¡¥Attributes¡¦ tab
Drag the preview frame to reveal a corner, drag corner to resize frame
Right click screen for Anchor positions.
With a bit of practice you should remove the vignette
Rollason
- ram: 3GB
Vignette removal
Thanks Steve. and Trevor for your snappy response.
I'll give that a try, Steve. and see how it goes. I assume it works for the whole selected clip in which case it should be really effective.
The help you chaps give is really appreciated.
Regards, Roy.
Regards, Roy.
Rollason
- ram: 3GB
Vignette removal
Hello again,
Further to the vignetting problem. As suggested I've clicked on the 'fill colour' box to clear the border and that worked fine. From the drop down menu to the left of 'customise filter' I selected the 8th box which, with 7, 9 and 10, are, I guess, fixed reduction borders. Are they as the percentage variation indication shows that this can be changed? I changed the height and width border percentage to 90%. On playing the clip I find that width and height gradually change back, over the course of the clip, to 85% which is what the border width was originally set at.
Is there some way of stopping this change from 90-85% as this creates movement in the clip?
I've tried the 'Stationary' box both cleared and uncleared with no apparent difference. Incidentally, as this appears to make no difference what does this box actually do?
Your further help would be appreciated.
Regards, Roy.
Regards, Roy.
Rollason
- ram: 3GB
Vignette removal
Hi Trevor.
Thank you for your help and that information. These programmes are supposed to be so intuitive but I guess that I'm lacking in intuition!. However, that works fine, all I have to do now is remember it the next time I need it. The video seems a wee bit jerky now but, hey, I've got rid of the vignette and you can't have everything.
Do you happen to know what the stationary box does?
Cheers and thanks again, Roy.
Re: Vignette removal
You can set the start position, defaults to the middle, but you can drag to one side, the end position can be in a different place, gives the effect of panning.Rollason wrote:Hi Trevor.
Stationary
Sets the start and finish in the same place.
Float the mouse over the left panel cross hair for hand sign.
Rollason
- ram: 3GB
Vignette removal
Hi Trevor,
Clarified! That's sorted that out.
Something else you might be able to help me with. Somehow I've trimmed one clip, top and bottom about 15% with a black bar. It looks a bit as if I've changed the clip from standard to wide angle by cropping top and bottom. I must have done it somehow whilst I was messing about trying to sort out the crop filter and now I can't remove it.
Can you advise me how to rectify this as I don't have the original clip?
Many thanks for your help. Roy.
Rollason
- ram: 3GB
Vignette removal
Thank you Steve for the quick reply.
As stated, the original clip is no longer available therefore I have to work with what I have. Can I open this clip up in some way to change it back to 4:3? I seem to have changed it to what appears to be 16:9. I would like to keep the width but increase the height. There is no filter, as far as I can see that allows me to do this. I've had a look at the tutorials but can find nothing appropriate. Maybe I've missed something.
Many thanks, Roy.
Many thanks, Roy.
Hi Roy
As Steve has said, the clip you see in the timeline is only a virtual clip, a thumbnail representing the file on your hard drive.
When we edit the clip in the timeline we do not change the original, only the virtual clip is changed.
First try this.
Click the clip in the timeline.
Select the Attributes tab
You should see a panel showing any Filters used.
Select the filter and hit the ¡¥X¡¦ to remove.
OK
Please right click the clip and select properties,
The properties window shows the file name, this contains the location of the original file saved on the hard drive.
If you cannot read the whole line click with mouse and use keyboard arrow keys to navigate.
Once you locate the file inserting again to the timeline will insert the un-edited clip.
First try this.
OK
Rollason
- ram: 3GB
Vignette removal
Hi Trevor,
I think that I'm confusing everybody on this one. The original has black bars top and bottom similar to a 16:9 clip. How that arose I don't know. I understand that the clip in the timeline is a virtual clip. The problem is with the original which I thought I had corrupted sorting out cropping. I realise that isn't so and that the bars are on the original. Maybe I video'd that clip in 16:9. No way of telling now and it's immaterial anyway.
In effect, I want to change the virtual copy of the original - which has the bars - and open up the virtual copy to a full screen picture. I hope that I'm now making sense.
Is this possible?
Regards, Roy.
Is this possible?
Regards, Roy.
- ram: 2 GB
- sound_card: Intel GMA 950
You cannot simply change a 4.3 to 16.9 or the other way round.Rollason wrote:....... the original clip is no longer available therefore I have to work with what I have. Can I open this clip up in some way to change it back to 4:3? I seem to have changed it to what appears to be 16:9. .....
You have two choices.
1. Stretch.
Here you distort the clip to either become wider (4.3 --> 16.9) or taller ( 16.9 --> 4.3). There are various ways to do this, either use the distort clip button, or place the clip on an overlay track and drag it to the required size.
2. Crop.
Sort of the opposite to the above method. Here you would enlarge the Video so that the video now fills the screen but you lose either the edges (16.9 mode) or the tops/bottoms (4.3 mode)
