Problem: UVS9, Microsoft Windows Installer 3.1 Windows 2000
GeorgeK
Post by GeorgeK »
Does anyone else run UVS9 on Windows 2000? And have you allowed Windows Update to install Microsoft Windows Installer 3.1?
I did and after this UVS9 terminates every time I attempt to capture DV or analog video.
The problem does not happen the first time I run UVS9 just after it is installed, but every subsequent time I run UVS9.
My initial solution was simple, reinstlall Windows 2000, install all other Windows Updates except for Microsoft Windows Installer 3.1, and then install UVS9 (and other applications that I use.
UVS8 worked perfectly with Video Capture.
However has anyone else has UVS9 and Microsoft Windows Installer 3.1 ?
Thanks,
George.
Hardware:
CPU: P4 2.0GHz
Memory: 512MB 330 MHz DDR RAM
HD: two 7500 RPM, 2MB Cache
Partitions in 1st Hard Drive: 20 GB for OS and Programs, 25 GB forPersonal Data, 30 GB for Capture only.
Partitions in 2st Hard Drive: 2x 60 GB for Video Projects.
Video Capture card: WinFast XP TV 2000 TV Tuner Card.
DVD Burner: Pioneer DVR-107D Single Layer times 8 burner.
Software:
OS: Windows 2000
Partion Format type: NTFS
Ulead Video Studio versions: UVS6, UVS7, UVS8, UVS9 (only using UVS9, now).
Still image editor: Ulead PhotoImpact 10.
Video Format used:
PAL DVD or PAL MPEG2, 720x576, Constant or Variable Bit Rates of 6000 to 8000 BPS.
Frame Type: Lower Field First, sometimes Frame Based.
Video Quality setting: default of 70%
Audio setting: LPCM or whatever that lets me fit all the video in on one 4.7GB DVD disk.
