Corel Videostudio X2 Transition Prombem
BEFORE you copy transitions from a previous version you MUST run VideoStudio at least once to prime the various libraries.
Then you can close VideoStudio, copy the transitions and other material from previous versions and then open VideoStudio again.
Now it will add the extra transitions to the primed libraries.
If you have copied the transitions over before you opened VideoStudio for the very first time then you need to remove ALL the transitions.
Delete the library files (You find their locations here). Run the VideoStudio installation program again and select the "Repair" option to restore the original transitions you deleted above.
Alternatively if you followed my suggestion of renaming the original folder containing your VFX or VFT files then simply restore them from that folder (Which is your backup)
1. Before you copy any transitions from the older vfx_plug directory - rename the existing one.
C:\Program Files\Corel\Corel VideoStudio 12\vfx_plug
rename to
C:\Program Files\Corel\Corel VideoStudio 12\vfx_plug_X2
Now proceed as I stated at the start of this post. Open VideoStudio to prime the libraries, close VideoStudio. Copy the other stuff over then open VideoStudio again.
I have now edited the procedure to include this important step.
go4saket
Post by go4saket »
I remember seeing one of your posts in which you had stated that Boris & Hollywood FX can be used with VS. I recently installed Boris but it didnt gie me any option to integrate it with VS. So, is there any other alternative that I can use. Moreover, by Hollywood FX, did you mean Pinnacle Hollywood FX. If yes, all its transitions have some unique file extension. How can I install the same to use it with VS.
