Project preview dimensions shrink - Please help!!
esclava
motherboard: MSI P67A-GD65
processor: Intel Core i7-2600K Sandy Bridge 3.4GHz
Video Card: MSI N460GTX CYCLONE 1GD5 OC GeForce GTX 460
Hard_Drive_Capacity: 5TB
Monitor/Display Make & Model: ASUS VK266H
Post by esclava »
Hello,
This is a really strange problem but I really don't think I'm the only one who's ever experienced it...
When I'm editing a video clip in 4:3 everything is fine. The clip fills up the whole preview window as it should. And then after some time, after a process of opening and closing my project file about 15-20 times, the preview window shows a border or frame around my video. This doesn't sound like a big deal, but it is because I have titles in my video and they all shift when this happens! Which is frustrating because if I'm still editing the video and I make a title to fit the "shrunk screen" it no longer fits the final rendered project.
My clip is in the main video track, not in an overlay track. I have not distorted my clip in any way or changed my project settings in any way.
Does anyone know the answer to my problem? Is there something I'm missing? I am a user of VS11.5-Plus and in VS12 and this occurs in both versions.
I will appreciate any help you can give me! Thank you!
~Esclava
esclava
Post by esclava »
I'm sorry, vidoman. I don't know how that happened!? I didn't mean to "double post."
~Esclava
esclava
Save as¡K causes 4:3 project to become 16:9!
Post by esclava »
Hello!
Does anyone know how to change your project back to the dimensions of 4:3 when it gets changed to 16:9?
Because after I posted this morning, I realized that there was more to my problem. Certain things trigger my ¡§project shrinking.¡¨
When I¡¦m editing any 4:3 file (I used some test clips that come with Ulead) my project immediately becomes 16:9 when I do the following:
1. Finish editing clip
2. Go to Share => Create Video File => Select any option (Same as first clip; WMV, Any form of .avi; ― anything besides .mpeg)
3. Press Cancel before beginning to render anything
4. Click the Dolby Digital Surround Sound Icon
And IMMEDIATELY the project changes. Here are some snapshot examples:
Before "Save As"
After "Save As"
I¡¦m totally safe if I choose any form of .mpeg and cancel, but all other file formats combined with the Dolby icon will cause my project to become 16:9. And this change cannot be reversed back to 4:3 by a simple Ctrl + Z or Undo command. You actually have to start from the beginning: File => New.
Now is this a bug or an oversight on my part? Is there a command to change the project preview back to 4:3? To my knowledge it is only the preview that is incorrect. When I render out the file, the finished file is in the normal 4:3 dimensions.
Any help is appreciated,
~Esclava
[/img]
Re: Project preview dimensions shrink - Please help!!
Post by Trevor Andrew »
esclava wrote:Hello,
~Esclava
Your images in the following posts clearly show the clips in the overlay track 1.
Right click a clip and select properties what are they?
Do this for all clips.............
Go to File- Project Properties, What are they?
Go to File Preferences, what is the background colour, shown in the lower panel????
Clevo
motherboard: Asus PK5
ram: 4GB
Hard_Drive_Capacity: 850GB
Post by Clevo »
Two things that I can think of:
When you first start VS there is little check box marked "16:9" in the first splash screen, make sure that is unchecked if intend working in 4:3
Also...check your project settings and make sure it too is set for 4:3
esclava
Post by esclava »
The point I was trying to make with my snapshots was not about the overlay track. I was pointing out how everything changes, including the overlay track. If you look at the new picture I'm posting you can notice the change in dimensions:
Here are the clip properties:
Here are the project properties before and after the Canceled Save/Surround Sound problem:
BEFORE:
NTSC drop frame (29.97 fps)
MPEG files
24 bits, 720 x 480, 29.97 fps
Lower Field First
(DVD-NTSC), 4:3
LPCM Audio, 48000 Hz, Stereo
AFTER:
MPEG files
Lower Field First
(DVD-NTSC), 16:9
Video data rate: Variable (Max. 6000 kbps)
Audio data rate: 384 kbps
Dolby Digital Audio, 48 KHz, 3/2(L,C,R,SL,SR)
In my project preference, my background color is black.
And I don¡¦t have the 16:9 box checked.
Thank you for your help.
~Esclava
Post by Black Lab »
