In all cases I'm getting the message "WinDVD MFC Application has stopped working" within a few seconds of the application window appearing. Windows Application event log shows this (example from my Vista PC) "Faulting application WinDVD.exe, version 9.0.14.91, time stamp 0x489aed03, faulting module MFC80.DLL, version 8.0.50727.1833, time stamp 0x482bc3e3, exception code 0xc0000005, fault offset 0x0004c0f3, process id 0x1f08, application start time 0x01c926662491f7d2".
I've gone through all recommendations I've found in this forum, namely uninstall + manual cleanup + reinstall with no firewall/antivirus; also installed the VB6 SP6 runtime components. It appears that none of these suggestions is addressing the issue.
My machines all have multiple copies of MFC80.dll, but only a couple of versions. In each case WinDVD.exe is loading version 8.0.50727.1833. The best explanation of why is here: http://phpbb.ulead.com.tw/EN/viewtopic. ... =mfc80+dll. A fairly good overview of WinSxS is here: https://thinstall.com/thintalk/viewtopic.php?p=360.
So, some questions - (1) Does anyone have WinDVD successfully running with MFC80.DLL version 8.0.50727.1833? (2) When I look at the manifest file in my WinDVD folder it refers to MFC80.DLL v8.0.50608.0. (3) Is this version necessary for WinDVD to run? If so, (4) how do I force it to use that version?
Thanks. I've spent hours trying to resolve this
