image fill
locky
image fill
Post by locky »
I have an object that I am using as a background, with text in the foreground.
I would like to fill the backgorund object with an image on my pc so I add a thumbnail in the My Gallery area of the toolbar. Problem is the image is much larger than the object. Is there a way so PI will stretch the image to fit the object? Aspect Ratio does not really matter terribly.
Many thanks
Locky
Welcome to the forums,
You might try making your object a selection, then use Edit>Paste>Fit into Selection.
locky
Post by locky »
fantastic, thankyou very much 8)
I'll also add that using the method I mentioned, does not provide for the background to be transparent. In other words, you get a white or black color surrounding the image pasted into the selection.
If you do need this, you could use the Extract Object, or one of the Selection tools, to cut around the object. Then copy/paste it. Here's an example:
The same photo of the dog was used for each...
