... error message
Nature of the problem
Playback of every DVD stops after a few seconds, and a green message appears in the WinDVD playback window, saying:
Stopp
Die Wiedergabe von geschützten Inhalten wird von Ihrer Anzeigekonfiguration nicht unterstützt.
(English translation:
Stop
The playback of protected contents is not supported by your display configuration.)
Properties of your source files (format, file size, where did you get it?)
Standard commercial movie DVDs bought in several retail stores in Germany. All of them play fine on my DVD player, on my wife's laptop computer which came with PowerDVD, and on a Linux PC.
What devices are involved and their mode of connection?
MSI Hermes 651P barebone PC with built-in DVD drive, CRT monitor connected by VGA cable (also tried with LCD display, makes no difference), pair of speakers connected by normal 2,5 mm audio plug, standard 105 key keyboard connected by PS/2 connector, Logitech Trackman Marble pointing device connected by PS/2 connector.
Project Properties
no project involved
Output format (file, DVD, VCD, SVCD)
VGA display
PAL or NTSC
PAL
Error Codes (if any)
Stopp
Stop
WinDVD 8 DVD playback stops after a few secs with a strange
Moderator: lata
on holiday
Just to keep the 24 hour reconfirmation deadline. More when back.
additional information
A few additional bits of information that might help assessing the problem:
1. The message
isn't mentioned anywhere in the documentation but I found a handful of reports of it in various online fora. Each time however, either the question itself or the responses were about playing one of the restricted new High Definition contents requiring an unbroken encryption chain with HDMI and the like. In my case, there is no High Definition or Premium content involved. I just try to play an ordinary Video DVD.
2. I tried to contact Corel support about that but was told the copy of WinDVD I bought in an online shop was an OEM version (seems I've been ripped off) and that therefore they wouldn't help me.
1. The message
Code: Select all
Stopp
RickinSav'h
- motherboard: Toshibia P55T-B5360
- processor: Intel Core i7-4710HQ
- ram: 16 GB
- Video Card: Radeon R9 M265X - 2GB DDR5
- sound_card: On Board
- Hard_Drive_Capacity: 1 TB
Me too
I'm using Win DVD 9 Gold. It was obtained via my purchase of MovieFactory Pro 7. Part of the bonus software. I've used it before for playing regular DVD's but this evening it starts up and within a couple of seconds I get a message the reads:
STOP
YOUR DISPLAY ENVIRONMENT DOES NOT SUPPORT PROTECTED CONTENT PLAYBACK
For what it's worth Windows media player 11 & Nero Showtime play the DVD fine.
STOP
Re: Me too
I guess we shouldn't expect any help with this.
Better look for an alternative product.
Linux solved my problem
Just to keep you posted:
In the meantime I switched from Windows to Linux.
The system came with a big choice of DVD player programs.
I tried several of them, and all of them played my DVDs just fine.
None of them complained about my display environment not supporting anything.
Hope that helps someone,
Tilman
Tilman
