Big and strange video studio problem!!!!!!!:S:S
Zinger
Post by Zinger »
hey guys,
i am using video studio 11 plus , the problem is when i try to share(create) an .avi movie there is a strange problem i choose .avi file then go to option click on the AVI tab the choose the divx 6.8 pro codec and when it comes to the audio format its the problem the ulead video studio can't recognize mpeg layer 2 or 3 it doesn't included in the audio format list while on my laptop i tried to install and everything is ok !!!! so plz help cuz i'm in a hurry :(
Zinger
Post by Zinger »
guys plz reply :'(
Welcome to the forums,
Sorry no one has replied before now....
Your source video clips are what form of avi? There are literally hundreds of various video formats (codecs) that use avi as a carrier or wrapper. Such as DivX, Xvid, DV, and many more.
I just had a quick test with VS11.5+, and it had no problems using MPEG Audio Layer-2 for the audio, along with DivX6.8...
Zinger
Post by Zinger »
thnx guys for help but the problem that when i go to share->custom->microsoft .avi files ->options->AVI (tab) -> Audio Format
the mpeg layer 2 and 3 doesn't exist in the audio format list :S
the source videos are .mpg recorded form DVB-S Application
Zinger
Post by Zinger »
See The Picture & u'll get my point
admin the topic: making templates u gave me i can't download any template from this site can u upload it on another site !!
You will find the new links further down the same thread
http://phpbb.ulead.com.tw/EN/viewtopic. ... 615#126615
By the screenshot you provided it is obvious that you're using Vista, so check the following path for the MPEG folder:
C:\Program Files\Common Files\Ulead Systems\MPEG, which should contain 70 files. This is where Ulead (Corel) stores the MPEG codecs.
In VS11.5 + this is what should be available. I used the same video clip as you have loaded, the same codec (DivX) and the audio codecs available are:
I would suspect a corrupt or faulty install of VS. You can also download a free codec checker like Sherlock or G-Spot which will check what codecs you have installed, and if any are broken.
Zinger
Post by Zinger »
vidoman wrote:By the screenshot you provided it is obvious that you're using Vista, so check the following path for the MPEG folder:
thanks guys for replying the mpeg layer 2 and 3 was working before i install the new asus motherboard and when i installed it i formated the C drive and installed new and clean version of windows vista and installed all the devices and installed VS and this problem happened i thought that the vista is corrupted and i formated again and installed it again and the same problem happened with VS for times
by the way my MPEG folder contains only 46 files not 70 !!!!!
i checked all the codecs that is installed on my pc and i found like 3 mpeg layers decoders :S:S and there's also another problem that when i install divx audio codec the audio format doesn't recognize it! :!:
Zinger
Post by Zinger »
guys plz respond i'm in a hurry :(
Zinger
Post by Zinger »
guys i'm waiting :?
It's not necessary to continually bump your own post. When someone comes up with a possible solution they will post it!!
Have you tried re-installing VS? As I mentioned I suspected a faulty install of it.
and there's also another problem that when i install divx audio codec the audio format doesn't recognize it! Exclamation
Is this from the DivX Pro package? If so then it's an issue for DivX not Corel/VS.
Have you installed any CODEC Packs ? These can wreak havoc with codecs that you already have installed.
Zinger
Post by Zinger »
vidoman wrote:It's not necessary to continually bump your own post. When someone comes up with a possible solution they will post it!!
no the divx audio isn't included in the divx pro package and i installed K-lite codec pack and another codec for the DVB-S program
Zinger
Post by Zinger »
up :roll:
Post by Black Lab »
As Ron has alluded to, codec packs often cause more harm than good. Try uninstalling the codec pack and see what happens.
