Resize Image for use in Video Studio
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
I am getting the top of some photos taken with a still camera chopped off
when exported to video studio 11+ when displayed in a PAL DVD.How do I resize these images in Paint Shop Pro X and what values should I use? ............................Ken
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
Size should be 768x576.
You'd need to crop the image.
Bear in mind though, that when seen on a normal tv you will lose approx 10% of the outside of the picture due to overscan.
Ken Veal
ram: 32 GB
resize Image
Post by Ken Veal »
thanks for that, can you advise me how I resize the image in Paint Shop
Pro X ?
allicorn
processor: Phenom II X6 1055T 3.2Ghz
ram: 4Gb
Video Card: ATI5670 1Gb + ATI4290 512Mb
sound_card: Realtek HD onboard
Hard_Drive_Capacity: 2Tb
Monitor/Display Make & Model: Belinea B2025S1W + LG M197WDP
Post by allicorn »
You can try using the Crop Tool from the main toolbar. It looks kinda like two interlocking "L" shapes with a diagonal line through them.
Choose that then in the Tool Options Palette make sure there's a check in "maintain aspect ratio", no check in "specify print size", select "pixels" on the "units" drop-down and enter "768" and "576" in the "width" and "height" boxes respectively.
You'll see most of your image kinda darken and a bright rectangle appear. The rectangle shows what area will be left when you confirm the crop. You can drag the corners of the rectangle to resize the or drag the middle of the rectangle to move it around.
If you drag the corners, changing the size, the "width" and "height" numbers will change of course, but thats okay. The important thing is that the overall shape of the rectangle is correct, we'll worry about the size afterward.
Once you've got the rectangle exactly where you want it, just click the green-circle-with-a-white-check icon on the Tool Options Palette. Your image get cut down to the right shape.
Lastly, from the menu go to Image -> Resize Image....
Put a check in "Advanced Settings" and another in "Resample Using..." if either of those don't have one already. Make sure "Smart Size" is selected in the "Resample Using" dropdown box.
Enter "768" and "576" into the "width" and "height" boxes under the middle section of the dialog which is labelled "pixel dimensions". Don't worry about the numbers under "print dimensions" - shouldn't be important for what you after.
Click OK and you're done. The image is exactly 768 by 576.
Alli
Ken Veal
ram: 32 GB
RESIZE IMAGE
Post by Ken Veal »
Great!
Could not have asked for a better reply-------------will give it a go asap...................................Ken
