Adding .gifs to the timeline
asustek
Post by asustek »
The program detects the .gif as a still image, not an animated image. i tried using different .gifs, but the problem resumes
NTSC/VS11
Welcome to the forums,
If you insert an animated GIF into the timeline using the Insert Image then VS will only use the first frame. However inserting an animated GIF into the timeline using the Insert Video, VS will play all the frames of the animated GIF file...
asustek
Post by asustek »
thank you
asustek
Post by asustek »
unfortunately, the error i get is, "misbatch error." i browsed around the forum and saw that others were experiencing the same problem. apparently, someone said that the newer versions of videostudio doesn't support .gifs in the video format, anymore.
gif animator is not an option
so, my question is, which version of videostudio support .gifs in the video format, or is there a plug-in?
You have not completed this Image so that we can then view your system specifications.
Are you running XP or Vista?
I would add to Steve's inquiry of which OS, what version of VS are you attempting to add animated GIFs to?
Currently on my laptop, running Vista Home Premium, I have VS10+, 11.5+ and VS Pro X2 installed. Of those VS10+ with the Vista Patch will not allow animated GIFs. VS11 and 12 (Pro X2) do. Also please note that VS10+ being run on an XP machine does allow animated GIF files.
asustek
Post by asustek »
im running on a XP machine
so only VS10 Plus allows .gifs?
Post by Black Lab »
No.
