HELLO! I have worked hours to get my audio/photos/everything in order and it's great!! ...EXCEPT when I go to burn the dvd - it ends up with a "thene" that I can't remove!!
Please help! I want to play it on our tv for guests at the party but it defaults to this stupid graphic that when I play the slideshow in the program - doesn't show up!
How do I remove the theme completely!? The box for theme's is unchecked under themes.
It forces me to click on "folder 1" at the first slide to over ride.
It's driving me crazy!!
(I had no luck delegating this job to my relatives! No wonder!;-)
(ulead dvd & pictureshow4)
PLEASE HELP!25TH WEDDING ANNIVERSARY DVD & STILL NOT DON
Yes! The box is unselected -
I have unclicked the box - that's why this is driving me crazy!
None of the themes would be something I would use - I do have some shadowing on the frames but that's it.
I even tried to start a new slideshow with a different name but somehow it ends up with the starting screen of the burned cd with a "theme" slide that forces you to click to proceed rather than just loading the cd and letting it run with the slideshow.
Any help you can give me with be greatly appreciated!
We've spent more time on this than the slideshow!! Thanks for the help!
- michaeltee
- motherboard: HP 82F1
- processor: Intel Core I5 7400 3 GHz
- ram: 16 GB DC
- Video Card: Intel HD Graphics 630
- Hard_Drive_Capacity: 2TB Hybrid
- Monitor/Display Make & Model: Samsung S24D300
- Corel programs: Installed: PS Pro 2021, VS Ultimate 2020
Hi LLW,
At this point what you need to do is "change" whatever elements of the theme you don't like. Using the various customization features of the software you can change the menu to a more appropriate style or even use a photo as your background image. You can also change the menu background music as well as the music that plays during your show. If you don't like the current transitions and/or pan/zoom effects you can change them as well. It's more a matter of substitution rather than "turning off" the theme. Fortunately it's not difficult and the illustrated user guide explains things pretty clearly. That said, I would definitely recommend that you save a project file of the show in it's present form before you begin experimenting. That way you won't have to re-start your project from scratch if you run into any problems or crashes. When you've got things the way you want, save a new project file using a different file name and then burn your show to a DVD. If you run into any specific problems let us know and we'll try to help.
Good luck!
-Mike
Good luck!
-Mike
heat_sync06
- motherboard: dont know
- processor: dont know
- ram: 448 MB
- Video Card: nvidia
- sound_card: dont know
- Hard_Drive_Capacity: 80 gig
Re: PLEASE HELP!25TH WEDDING ANNIVERSARY DVD & STILL NOT DON
Thanks for the info. I was having the same problem good thing i saw this thread. Thanks.
