I am using VS11.5+ and tried to import my own produced and burned DVD. It went through the parsing and the Import DVD screen appeared. Under info only Label, Format DVD Video, TV Syusten, NTSC 30 fps were shown. Upon clicking the Chapters to be imported in the Import DVD --> "Disc label" window, it hung up and a message appeared that VS encountered a problem and needs to closed.
The error says: AppName: videostudio AppVer 11.0.0.0 ModName h264vdechpdll.dll ModVer 1.0.0.15 Offset: 00050ae6.
Then I tried to import using VS10+ and VS9, and the same error appeared.
In the past I was able to import a DVD without any problems under VS9.
Could someone help me how I should correct the problem or tell me why now I have troubles in importing the DVD?
Thank you.
Import DVD
Bimbing
- motherboard: Pegatron Odessa chipset H 110
- processor: Intel i7-6700 3.4 GHz 4 core
- ram: 16 GB
- Video Card: NVDIA GeForce GTX 745
- sound_card: NVIDIA High Definition Audio Audio Codec ALC3863
- Hard_Drive_Capacity: 5450 GB
- Monitor/Display Make & Model: HP 2009m
- Corel programs: Ulead Videostudio X4
- ram: 2 GB
- sound_card: Intel GMA 950
Please view:
Fix: Import DVD (VOB) Files DMF/VS/MSP
Bimbing
- ram: 16 GB
Bimbing
- ram: 16 GB
Thanks again sjj1805.
Follow up. I search for the h264vdechpdll.dll file and found only one file of 993 KB, although I have VS9, VS10+ and VS11+ on my computer.
In your case after installing VS11+, you said you had the same problem but it was cured using the same method. Do you mean that you rename the 993KB file h264vdechpdll.old and use the 413 KB file instead?
