Your brilliant fault finding skills are required again please. Ive tried searching through the forum but could find this problem. (forgive me if Ive missed it).
I am having problems creating video files.
I have previous created a number of project with no problems but now the project either locks up or it skips trough the rendering process when trying to create the Video File. I.e for a 10min clip it will jump from 1% to 35% then to 60% then 90% then either freezes for a few sec or if I'm lucky it will play the sound of the project with a few static scenes. If not I'll have to do Alt + ctr+ del and end VS10 session.
Not sure if this has anything to do with it but my problem started after I burnt a 50min DVD in 16:9 (but as the project didn't fill my widescreen TV properly) I've then tried to burn another project in 4:3. (I wouldn't have thought this had anything to do with it)
Over the past few days Ive tried tried opening other projects and clicked on Create Video file but its still the same it just freezes. Is there anything like a simple refresh button, or clearing the cookies or unwanted files in VS10?
As said I've burnt several projects using the same equipment but I am coping from a: Sony mini/DV camera into Ulead VideoStudio 10.0.
I dont want to reinstall VS10 as Ive got about 2hrs worth of edited video complete with sound / image effects, chapters points you name it, just waiting to burn.
An example of one of my projects is:
PAL (25 fps)
MPEG files
24 bits, 720 x 576, 25 fps
Lower Field First
(DVD-PAL), 4:3
LPCM Audio, 48000 Hz, Stereo
I've always kept my projects on an external Hard drive (just in case I run out of working space).
I am in London, England.
The PC I am using is a: HP Pavilion Intel(R)
Pentium(R) 4 CPU 3.00GHz, 1GB of RAM
MS Windows XP
Home Edition
Version 2002
Service Pack 2
Can anyone help?
Douglas
