Hi Experts,
I am having and issue with VS 11 plus. For some reason the audio sync is out on part of my project after I render it using VS/Create disc function.
I have tried several different things to try and fix this like pulling the affected portion and rendering it in a new project but I still get the same results. I have also tried using mpeg optimizer as well as normal rendering method.
The original video is fine and even in preview mode it works fine.
Any tips or ideas to work this out would be great.
Audio sync issue
You don't tell us what kind of video format you are dealing with, nor the exact steps you took in your workflow.
However, in the past, most audio sync problems were solved when you switch off SmartRender. It is probably also better to edit your project, then render it to a single new file (Share > Create Video File > DVD), and then in a separate step burn that new file to DVD. That way you can first test the new file to see if sync is OK. And if it isn't, then you can do it again and turn off SmartRender this time.
If it is then OK, you can then burn it, making sure that 'do not convert compliant mpeg files' is ticked in the middle of the three icons in the bottom left of the burning screen.
