Possible bug in Pro X2 (trial) AVCHD disc burning process
Posted: Sat Sep 20, 2008 4:15 am
Background: 1920x1080 DD5.1 AVCHD clips from a Sony SR11. Using Pro X2 trial to edit and then create AVCHD discs on standard DVD+R media, keeping the same file resolution and other characteristics as the original video clips. My system is an Intel quad core Q9550 2.83 GHz, 4 gigs RAM, Vista Ultimate 64 bit.
I had success on 2 projects using the MPEG optimizer and smart rendering. These projects had little editing of the clips themselves, but contained fade-to-black transitions between each clip, and a title and ending credits over black color boards. Audio and video were in sync and looked good when the end-product AVCHD disc was played on my Panasonic BD30 Blu-ray player. (This was all before reading advice to avoid the mpeg optimizer and smart rendering with AVCHD.)
Then I started a new project with different clips from the same camcorder. I did some editing (color correction in a couple clips, subtitles in 2 clips, and a title over a black color board, no transitions this time). As with the first two projects, I used the MPEG Optimizer and Smart Rendering to create a file with the same characteristics as the video clips (1920x1080, DD 5.1, upper field first, etc.). Then burned an AVCHD disc on DVD+R from this file. As before, I checked-marked the option to not convert mpeg compliant video, so the burn process was very fast - no conversion took place.
The resulting disc has audio/video sync problems when I play it in the Panasonic Blu-ray player; the further into the disc, the more the audio is ahead of the video. So I figured that the advice to not use the mpeg optimzer and smart render was right.
BUT... then I used Pro X2 to just play the .mpg file that had been created with the mpeg optimizer and with smart render on (and that was out of sync when burned to disc). The file itself played in-sync within Pro X2. As a double check, I also played the file in PowerDVD 8, and it played in sync.
Since the .mpg file itself is in sync, but when burned as an AVCHD disc it is out-of sync, it seems that the out-of-sync condition must have been created during the disc burning step, not during the file creation process (which is where the mpeg optimizer and smart render come into play).
The burning step did not re-render the video. It only took about 2 minutes to create the disc of 5 minutes of video. The burn process went right to the "dispatching ouput" step and never said "converting title" or whatever it says when it is re-rendering. It should just be creating the disc folder structure and coping the video/audio with no alterations (I would think anyway).
I am suspicious of the step that occurs during burning that is labled "Audio/Video multiplexing". Not sure what that does, but by its name, it sounds like an opportunity to introduce sync problems.
I wonder whether there is a bug in Pro X2's AVCHD disc creation process that causes this sync problem, at least under some circumstances? It was OK for 2 projects and a problem with the latest project.
Has anyone else experienced sync problems on AVCHD discs, but checked the underlying file and found it to be in sync?
