VS9 - Preview Not Good
Rich2Putt
operating_system: Mac
processor: 2.9
ram: 8gb
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: IMac AIO
Post by Rich2Putt »
PC - P4-3.0
512 RAM
160 gig HD dedicated to VS9
With VS9, when I use preview, the playback is very jumpy and the sound is either ahead or behind the video, or digital pixels show on the preview screen (difficult to "rubber band" the sounds).
In preference menu, I use "instant playback" rather then "high quaility". I had used this setting in VS8 and the playback was much more stable.
Is there a way to view a more stable preview? Any suggestions would be appreciated. Also could "smart render" be causing this? If so, how do you disable it?.....
Thanks.........
MikeGunter
Post by MikeGunter »
I would check to see how many processes are running in the background. That and the amount of video processing on the timeline, speed of computer, all make a difference.
Try EnditAllto close all programs.
Good luck,
Mike
THoff
Post by THoff »
You may also have set the Preview target to something other than just the Preview window. If it's set to include a DV device that's not hooked up or turned on, or a dual-head device that requires rendering to a second display, it could slow things down.
Rich2Putt
processor: 2.9
ram: 8gb
Post by Rich2Putt »
How does one change the "preview" target?
I have an ADS analog to digital converter box and it's always turned off when not in use.
I seen the dual device setting somewhere. I'll look at it tonight when I leave work.
Thanks for the info..........
THoff
Post by THoff »
It's in the Preferences, in the General tab.
Rich2Putt
processor: 2.9
ram: 8gb
Post by Rich2Putt »
Thank You !!!!!!!!!!!!!!
