Been extremely bausy with family and work matters for the last 2 months (excuse out of the way).
Have been patiently waiting for VS12 since I was told I could "upgrade" from VS8 which I use (latter not compatible with Vista) whereas I could not upgrade to 11.5 etc.
Is the Pro X2 a proxy for VS12?
TJ
Breathtakingly obvious question..
Antonio y Anna
Just be aware that, depending on where you are, there is a X2 Standard, X2 Pro, and X2 Ultimate.
X2 Standard is like v11 (only 1 overlay track), X2 Pro is similar to the old "+" versions (multiple overlays, etc.), and X2 Ultimate is identical to X2 Pro, but comes with addtional software.
Jeff
Dentler's Dog Training, LLC
Many thanks
Thanks for the clarification.
Just out of interest do all 3 versions have the same glitch with analogue capture? (unable to capture)
TJ
TJ
Antonio y Anna
I don't know that anyone has tried all 3 version to confirm, but I would think if they all use the same capture plug-in then any problem would be in all 3 versions.
Jeff
The only analogue capture glitch is capture from a Sony Digital 8 playing an analogue 8mm or Hi8 tape, via Firewire. All other analogue capture of DV is fine. With capture of mpeg-2 and other formats via USB devices, the same situation as before applies: it depends on the device. And our advice remains the same: use the software which came with the device for capture and open the captured video for editing in X2.
