Burning Speed MF7 Pro
randazzo
Post by randazzo »
When burning a video-DVD I cannot change the burning speed. Normally I want to burn a DVD on the lowest speed available . This gives less chances on burning issues.
But the burning speed is greyed out and automatically set to maximum. I can not change it. Am I doing something wrong?
Jean-Pierre Randazzo
RickinSav'h
motherboard: Toshibia P55T-B5360
processor: Intel Core i7-4710HQ
ram: 16 GB
Video Card: Radeon R9 M265X - 2GB DDR5
sound_card: On Board
Hard_Drive_Capacity: 1 TB
Post by RickinSav'h »
Same here, set at maximum & greyed out.
It worked fine, DVD-R plays fine in computer & 2 different brand DVD players.
Looking fwd to suggestions...
Just checked and mine is greyed out also.
Burn a disc image file and then use the Copy Disc option from the
MovieFactory 7 launcher - it allows you to reduce the burn speed.
randazzo
Post by randazzo »
Good tip. Thanks!
nyquist1
motherboard: Gigabyte EP43-US3L
processor: Intel E7500 Dual Core
ram: 2GB
Video Card: ATI Radeon HD4350
sound_card: Realtek high definition audio
Hard_Drive_Capacity: 800MB
Re: Burning Speed MF7 Pro
Post by nyquist1 »
A belated reply - Itoo have been frustrated re the the burning speed option being greyed out. Regarding the suggestion of "burning a disc image file" there does not seem to be an option for this on the "burn page" (in contrst to MF6 where there is one). Is this option hidden away some where?
To the right of the Create to Disc, Recording Format box should be a double down-arrow. Click it to expose more options. These options should be Create DVD Folders, and Create Disc Image. The latter would be the one to create an ISO file.
nyquist1
ram: 2GB
Post by nyquist1 »
Hi RonP,
Thanks for info - so obvious after being told! My problem related to using a DVD drive with a maximum capability of 22x writing speed however the DVD blanks were only rated for 16x.
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
The dvd drive will check the disc to see what speed it can be burned at, and will only burn a 16x at 16x, so long as you are buying decent discs, where they put the data on the disc for the drive to read.
And most of us here -- though not all -- would in any case advise *against* using the maximum rated speed to burn a DVD. Instead, we would recommend you use a much lower speed e.g. for a 22x or 16x, I would use not more than 8x. The idea is that using a lower speed enables the burning laser a little more time to firmly embed the video signal into the disc. That in turn should help a wider variety of reading lasers in stand-along DVD players to be able to read the signal and play it back without problems...
stelch
motherboard: Fujitsu Siemens
processor: Intel Xeon processor E31240 8 MB 3.30 GHzz
Video Card: NVIDIA Quadro 2000 1GB
sound_card: Realtek
Hard_Drive_Capacity: 2 x 1 Terr
Post by stelch »
How do you set the burning speed on MF7?
VideoStudio Pro X6 Ultimate
MovieFactory 7 plus
You can't set the burning speed in DVD MF7. I don't know why it's that way in this version.
stelch
sound_card: Realtek
Post by stelch »
what a pity, what a pity. Lets hope that the next version (if there is going to be one) tackles this problem.
stelios
MovieFactory 7 plus
