Video Studio X2 Wish List for Future Versions
johnrule
Post by johnrule »
Black Lab wrote:
6) Option to ignore video track audio totally (disable?). Currently, I must either split the tracks and delete the audio, or I must use the volume control track to lower the volume to zero.
Simply click the Mute button.
Not for me.
Add a video track with its own audio.
Add a music track.
Go to the Audio View.
Mute the audio for the video track.
Go back to the Timeline View.
Play all.
I still get the audio from the "muted" video track.
Thanks,
JR
www.xsyscontroller.com
Dominic
Post by Dominic »
1. The ability to preview a timestamp on the video so that way I wont have to rewind on the camera and see what date and time the video was recorded, because sometimes I record different days and that would be useful especially for movies or documentary tapes.
2. To save each video filter used as a customized filter because I have to manually adjust the lighting or whatever filter I use each time I go to the next clip, which would save a lot of time in the editing process.
3. Have a tab for a video filter applied to all clips instead of manually putting them one by one, again saving much more time.
4. There's a bubble and lightning filter, how bout a starburst zoom video filter or flash file with the ability to have as many glints on the star as it zooms towards the screen? I have been looking for a way to create an awesome starburst zoom for flash with glints on the flying stars, but the net is limited and it would take time to create the effect from scratch.
5. As a previous user posted, the use of a velocity curve on the video and photo pan and zoom filter to prevent the sudden jerky start/stop and create a nice smooth intro or stop. This would be especially useful for TIF image files with the black area chroma keyed out, such as for titles, credits, etc.
6. If there's a faster way to create psychedelic colors via the color filter then tell me because it would be cool if I wouldn't have to manually go frame by frame to make the awesome array of colors on the video.
7. Create a Master Effects key like the professional switchboards do. Such as for example create a video fullscreen, then squeeze the video down a 1/4 of the screen with an image or other video behind it.
8. Finally, the ability to flip the video horizontally or vertically. Let me know if I missed this, but I can't find that button anywhere.
nuovagrafica
Post by nuovagrafica »
Hi, it is possible to fix this bugs with a new patch or in the next version?
1- when in the video track or in the overlay track I select a video and than I click on the button go to the end frame the current frame is wrong, so if I cut without zoom in the timeline the cut is wrong
2- if I select a video in the timeline and I change the volume for example to 200% and then I split audio, volume audio is 100%, maybe X2 must advice when it changes my setting because if I forget to change volume to 200% editing could be wrong. If I split audio is because I wont use this audio and another video in the overlay track. A solution Could be that X2 tell us: Attention volume audio in changed! wuold you like reset volume audio to 100% or use the new setting? YES / NO
3- some plugins that work in VS 12 doesn't work automatically in the X2, It is possible enlarge compatibility to others plugin's?
I don't understand your (3) -- VS12 and X2 are one and the same product! :roll:
nuovagrafica
ulead video studio 12 and corel X2 are two different products, some plugins install a vfx file in ulead folder. When you install corel x2 ulead folder don't exist but the main folder of x2 is named corel, so some plugins you must install manually.
nuovagrafica wrote:ulead video studio 12 and corel X2 are two different products, some plugins install a vfx file in ulead folder. When you install corel x2 ulead folder don't exist but the main folder of x2 is named corel, so some plugins you must install manually.
Nope - they are one and the same.
rjkowalski
Wish List
Post by rjkowalski »
1. TOP PRIORITY: I wish the software would do a better job automatically optimizing the compression onto single DVD disks. I spent way more time burning the DVD than editing the video. And....perhaps even a slider for video compression & audio changes so that you can choose whether to sacrifice video or audio quality during compression. Right now, it's harder to get good DVD quality than it is to edit.
2. Allow transitions to be tacked on front or end of video without having to enter a color frame (ie, easier fades in & out)
3. Allow selection of the portion of video you want the motion menu to show.
4. Add Save button on each screen of DVD creation.
Re 1: From what you say, I suspect you are editing then, instead of first producing a DVD-compatible mpeg-2 (which is also compatible in terms size/length in relation to the type of DVD blank you will burn it to), you immediately jump to the burning module and use the project file there. That means the compression has to take place during the burning process, which is already a fairly complicated process in its own right.
If so, that is perfectly OK and it usually works. But over the years, quite a few users have encountered various problems with that workflow, one of the least of which is getting the compression (i.e. the bitrate) right so that your project fits on a single layer DVD. For many of us the preferred workflow is to finish editing, and before you even think about opening the burning module, you first go to Share > Create Video File and create a DVD-compatible mpeg-2 whose compression/bitrate can be properly controlled by the user. If the project is an hour or less, then you can use the default Share > Create Video File > DVD template (as long as the Field Order in it is consistent with the video in your project.) If your project is longer than an hour, then you have to vary the bitrate downwards by using Share > Create Video File > Custom. If its only 10 minutes or less over an hour, then you can simply choose a more compressed audio bitrate. But if the project is around 90 minutes, you would need to reduce the video bitrate from the default 8000 kbps down to around 6000 kbps; and if 2 hours -- 4500 kbps.
Note also that after you produce your new mpeg-2, you go to File > New Project. Don't worry about giving your new project a name. The objective is just to clear the timeline of your current project. Once that is done, you select Share > Create Disc > DVD. The burning module will open. Use the Add Media button at the top to insert your new mpeg-2 in the burning timeline. Then go to the middle of the three icons in the bottom left of the burning screen. There is a little box beside the words 'Do not convert compliant mpeg files'. Make sure that box is ticked (it usually is by default). That way, your already compliant mpeg file will not be re-encoded. Then build your menus and burn. Following this workflow, the entire burning process should take no more than about half an hour at a burning speed of 4x.
Re 2: We have been asking for this for years, with no result.
Re 3: Already there and has been for several versions now.
Re 4: See my comment on 2 above! :cry:
Incidentally, there was a compression module built into an earlier version of VS -- I think it was VS9. But it was never very good -- only really worked when the project was just a smidgin over what would fit on a DVD. So it was dropped...
rjkowalski
Clip for Motion Menu
Regarding selecting what part of clip to show in motion menu. How? I double-clicked & right-clicked the frame that shows the video within the main menu. I can't find an option to select what video portion to repeat within the frame.
Thanks again,
Rick
Once you have selected the background video, there are two small, unlabelled icons over to the right of the words 'Background image/video'. If you hover your mouse over the second one, you will see that it says 'Set start position of background video'. Click that and a little preview screen comes up. You move its jog slider to where you want the background video to start! :lol: Easy peasy!! :wink:
rjkowalski
Video on Menu
That sets the video in the full screen background but not the video in the inset window that appears over that background. The small window is using the very beginning of the first clip on the timeline. Maybe I'm overlooking that one.....I'll look further.
Re: Video on Menu
Post by Black Lab »
rjkowalski wrote:That sets the video in the full screen background but not the video in the inset window that appears over that background. The small window is using the very beginning of the first clip on the timeline. Maybe I'm overlooking that one.....I'll look further.
Double-click on the thumbnail. That opens the Start Position window. Use the slider or the timecode to set the beginning of your clip.
rjkowalski
Maybe it's the menu
I'm using the DV5vs_OneS17 menu. It has a motion background with a thumbnail window over a star. I can set the start & stop of the full background but can't figure out how to change what appears in the thumbnail window. I select it, double-click it, etc. I can't even delete that box. Next time, I'll try another menu.
aafuss
motherboard: ASUS M2N-MX
processor: AMD Sempron 3200+
ram: 1GB
Video Card: ECS GeForce 8600GT
sound_card: Creative Sound Blaster Audigy Value
Hard_Drive_Capacity: 80GB
Post by aafuss »
Would enjoy seeing some new transitions in the next version.
A.A.'s Ulead/Corel software:VideoStudio X4, PhotoImpact X3, PaintShop Pro X3, PaintShop Photo Express 2010.
johnrule
Another cursor comment
Post by johnrule »
I have stated this before (as many others have) but it is just plain ridiculous and it needs to be fixed: the cursor should not move when you click on a segment! :evil:
There is no good reason for this behavior...and the workarounds are lame.
JR
Locked
