VideoStudio 10 "Encouters a problem" after loading
Clement Saggers
I have Ulead VideoStudio 10 plus, and up until now it's been working fine. After the program loads I get a "Vstudio.exe has encounted a problem and must close" error. I don't know why it's doing it. The program seems to be working, if I ignore the error I can still use it. I recently installed Auto Gordian Knot so I can convert to Xvid, and this is when the problems seemed to start. But some time ago I installed AGK on my other computer which also has Videostudio 10 plus on it, and I've had no problems at all, so I'm not sure if AGK is the source of the problem or not. What can I do?
Well, you could try removing the AGK from you system and see if that works. Or, do a System Restore to be sure you get everything.
I used to get a similar error once in a while and could simply move the box out of the way and continue working, as you have stated. But now it won't let me do that and I must restart VS. This happens infrequently so is not a big deal.
Jeff
Dentler's Dog Training, LLC
