add a font to PI
TomD
add a font to PI
Post by TomD »
There's a font I want to use that is not included in PI. I downloaded it from the web and have the .ttf file.
Is there a way to install this font into PI ?
Xyzzy2
motherboard: MSI Z77MA-G45
processor: Intel i5-3570K
ram: 8 GB
Video Card: MSI R7770-2PMD1GD5 OC
sound_card: Realtek 892
Hard_Drive_Capacity: 6.25 TB
Monitor/Display Make & Model: HP ZR24w
Post by Xyzzy2 »
try Control Panel >Fonts, File>Install New Font
heinz-oz
Post by heinz-oz »
All you need to do is to install/add this font to Windows via the control panel. It will then be available in PI also.
TomD
Post by TomD »
Yikes! That was easy. Thanks very much!!
Tom
trueblue
Moderator
motherboard: ASUS Z97M Plus
processor: Intel Core i7-4790 CPU 3.60 GHz
ram: 12GB
Video Card: NVIDIA GeForce GTX 750
sound_card: NVIDIA High Def Audio Realtek High Def
Hard_Drive_Capacity: 1.740GB
Monitor/Display Make & Model: Benq E2420HD 24" wide x 2 monitors
Corel programs: PSPX8-VideoStudio-AfterShot
Post by trueblue »
You don't have to install the font into your Windows/Fonts.......if you only wish to use the font once there's a quick and simple way to use it in PI.
This method also prevents installing too many fonts which could cause PI to crash.
Go to the folder where you downloaded the font and open it. Double click on the font file that's within the zip window so that it opens fully.
Now that it's open, open PI [if PI is already open, just click on a different tool then back to the Text Tool] Open the Text list on the Attribute bar and find the font you have open on your desktop. It should be there ready for you to use.
When you close the Font file, the font will also disappear in PI.
Try to keep the minimum of fonts in your system but never uninstall System Fonts.
Hope this helps.
~~~~Maureen~~~~
Creative-Designs
Free! PaintShop Pro Tutorials
KPPang
Post by KPPang »
Hello, do you mean open 'TrueType Font File'?
Ok, window opened -
No font listed?
Am using PI X2
trueblue
Moderator
ram: 12GB
Post by trueblue »
1. Open PI
2. Open the truetype font file (NOT in PI)
3. If you have the Text Tool selected, just selected another tool then go back to the text tool.
4. Scroll down the drop-down box and the truetype font you chose will be visible in the PI window for you to use.
5. Once you close the truetype font file, the font will also go from PI.
Doing it this way prevents you installing large volumes of fonts into your Windows Fonts.
~~~~Maureen~~~~
Creative-Designs
KPPang
Post by KPPang »
Ta, Maureen,
It worked after a few attempts...
Fonts didn't work when they are ?? in zip folder?? maybe..
Copy pasted into new folder and extracted them from this file and
it works.
Thankyou :D
trueblue
Moderator
ram: 12GB
Post by trueblue »
Yes, you must extract the text file into a folder. I have a Fonts Folder that I extract fonts that I don't necessarily wish to add to my Windows system.
Remember, when you open the font and use it for PI, it's only temporary. As soon as you close the font window, it's no longer useable in PI.
It's just a great way of using a font temporarily for a special project.
~~~~Maureen~~~~
Creative-Designs
KPPang
Post by KPPang »
Thanks :lol: Maureen, meant to reply that all's going well.
Cheers
