Hello!
I've made about 10 videos with UVS 11Plus and then uploaded them to google video... In the past I had save them by doing this:
Share > Share Video Online > Neptune > Highest quality (¡K640x480)
I realize this is the same as:
Share > create video file > wmv > WMV Zune (640x480, 30fps)
But now today I hit a road block. When I save out a file with this setting, my dimensions are no longer 640x480, but 208x160!!
Then when I go into options to customize my own settings, the option for making the dimensions 640x480 are grayed out.
Am I the only one with this problem??? I would appreciate any help in this regard.
BTW: I un-installed the whole program and did a repair¡Kstill the same!
Thanks!
~Esclava
WMV Dimension option grayed out!?
esclava
- motherboard: MSI P67A-GD65
- processor: Intel Core i7-2600K Sandy Bridge 3.4GHz
- Video Card: MSI N460GTX CYCLONE 1GD5 OC GeForce GTX 460
- Hard_Drive_Capacity: 5TB
- Monitor/Display Make & Model: ASUS VK266H
esclava
esclava
It was CORRUPTED!
Thank you for the Media Encoder 9 suggestion! I DID have it installed on my primary computer and my other pc... So I installed the original UVS11.5 on my primary machine and on the other one I installed the trial. I decided to try every option available so I finally did an un-install and re-install of this Microsoft component and now it's working! So aparently, when I did automatic updates (which I'm skeptical about anyways) it was a corrupted install!
Thanks again for your help!
~Esclava
~Esclava
