Transparent areas of png files aren't!, MF pro 7
RickinSav'h
motherboard: Toshibia P55T-B5360
processor: Intel Core i7-4710HQ
ram: 16 GB
Video Card: Radeon R9 M265X - 2GB DDR5
sound_card: On Board
Hard_Drive_Capacity: 1 TB
Post by RickinSav'h »
When png files are added to a DVD menu as a decoration the transparent areas of the files are not transparent but white. I thought that was the whole idea of using png files over jpg's.
The files do in fact have transparent areas as they show up in Photoshop correctly.
Any ideas?
randazzo
Post by randazzo »
I'm not 100% sure but it could be that the DVD menu editor is different from a video or photo editor. Which support things like chroma keying and transparant parts. Don't think the DVD menu editor is made that way.
Jean-Pierre Randazzo
RickinSav'h
ram: 16 GB
Jean-Pierre,
Thanks for the reply. Maybe you're right. But I hope not.
MF Pro 7 accepts *.swf files with transparency as decorations but not *.png's. Maybe there will be a fix out soon.
etech6355
Post by etech6355 »
If your making your own PNG's what is your "Alpha" channel setting for the Png file?
RickinSav'h
ram: 16 GB
The files I'm attempting to use are png files that came with VS 11.5+!
C:\Program Files\Ulead Systems\Ulead VideoStudio 11\Samples\Decoration
Not sure about the alpha channel on png files. When I open "D01.png" from the directory reference above in Photoshop there is no alpha channel listed only channels listed are: RGB, Red, Green, & Blue.
The images are clearly transparent as you can see the tell tale checkered pattern as a background. Sorry about the pun :oops:
