Actually, add to that another project I'm working on for which I also converted several files of various original formats into compliant MPG....and four of those files also came out in the other project with NO sound. I tried recoverting them, but still had the same problem. I even tried using Any Video Converter instead of Super!, and replaced the problem files in the project with the ones converted through AVC, and same thing. Tried clearing the temporary working folder and temp files for DMF, and no luck....same thing happens with both projects.
What the heck is causing this to happen, and always on the same files? This is the first time this has happened to me, and the first time it's happened with video files converted through Super!....which has never given me any major problems so far. Also, on these problem files which end up with no sound in my final ISO, I've also attempted using both filters in Super! (the FFmpeg and the MEncoder options), and neither one makes any difference. Have also tried different bitrates and sampling rates, etc. (although I try to keep the conversions to match the DMF project settings).....NOTHING makes any difference. The problem clearly seems to be in DMF itself.
HELP!
