change duration of multiple images
I have a 9 minute video of about 100 or so pictures. Each image plays about 5 seconds. I want to increase each picture to play for 7 or 8 seconds. Can I change the duration of each image without going into each image separately?
Thanks in advance,
John
Toledo, OH
Thanks in advance,
John
Toledo, OH
Click on the first one, press and hold the Shift key, click on the last one.
Jeff
Dentler's Dog Training, LLC
aintnothin
- motherboard: asuss
- processor: amd quad
- ram: 4GB
- Video Card: nonee
- sound_card: nonee
- Hard_Drive_Capacity: 700GB
- Monitor/Display Make & Model: Hannspree
Re: change duration of multiple images
Using X4 --
Selecting multiple clips only seems to work in Timeline mode -- which also selects my transitions. Is this correct?
Secondly, which menu selection to apply a new duration to all of them?
Thank you
Thank you
As mentioned earlier in this post:-
Using the mouse select the first image.
Hold the Shift key down then select the last image, all images between will be selected.
For X4 choose Edit-Change Photo/Colour Duration.
This will only change the image duration NOT the transitions
aintnothin
- ram: 4GB
- Video Card: nonee
- sound_card: nonee
After selecting multiple photos in timeline or storyboard, that Edit option is not enabled, either from the Edit menu or via mouse right-click.
Thank you
Thank you
It is only available for the Main Video track. If your photos are in an overlay track, you will have to either move them to the Main track, then use the aforementioned to change the duration, or change each one separately.
aintnothin
- ram: 4GB
- Video Card: nonee
- sound_card: nonee
My photos are only in the main video track (the top one).
Thank you
Thank you
You should have these menu options...
Timeline mode, photos selected, right-click; Edit Menu: Storyboard mode, right-click on photos; What format are the photos? Maybe that is what's causing the problem???
aintnothin
- ram: 4GB
- Video Card: nonee
- sound_card: nonee
Thank you for all your screenshots!
Except, in my case the option to change duration is always dimmed (disabled) unless I am doing 1 photo at a time. They are all JPEGs.
Thanks again
Thanks again
Standard ol' JPEG or Progressive? I don't think VS likes the progressive flavor much. If they are rock standard JPEG, then there's something messed up with your installation of VS.
