On the bottom bar showing the estimated size to be burnt to DVD, a problem. If I import MPG files, it shows the correct size.
If I import an .avi file, it always seems to assume I am encoding at 7000 kb/s, irrespective of my compression setting. I.e. when I want to encode at 5000 kb/s, it dows not allow me to add as much video at it should for 5000 kb/s.
So when I add (say) 1 hr 45 minutes of .avi video and select 5000 kb/s, which should fit nicely, DVDMF4 refuses to burn as the file is "too big". If I create the 5000 kb/s .MPG file of 1 hr 45 minutes in MSP7, and then bring it into DVDMF4 for burning, all works fine.
In DVDMF2. the problem does not occur. It works perfectly (but does not support dual-layer disks). As I change the bit rate for mpg compression, the change in size is immediately and correctly reflected on the size bar.
In DVDMF3, I have the same problem as with DVDMF4.
Any others seen this? Any solutions / work-arounds? Is this a known bug?
Cheers,
Arnie.
P4-3.0
MSP7
DVDMF4
Working with PAL video
