CONVERT FILES
sayer
CONVERT FILES
Post by sayer »
Can you convert Video Studeo & Media Studio Files back to mpeg files after you have edited them
Devil
Post by Devil »
Normally, yes, using Create in MSP. However, you tell us only a part of your story. We would need to know the format they are in to start with, project settings etc., because there are a few limitations which might make conversion difficult or very time-consuming.
sayer
CONVERT FILES
Post by sayer »
When I use MF6+ I get this message!
Project Properties
MPEG files
24 bits, 720 x 576, 25fps
Frame-based
(DVD-PAL), 4.3
Video data rate: Variable (Max, 7000 kbps)
Audio data rate: 256 kbps
Dolby Digital Audio, 48 KHz, 2/0(L, R)
Video Properties
MPEG files
Upper Field First
(DVD-PAL), 4.3
Video data rate: Variable (Max 4400 kbps)
Audio data rate: 384 kbps
MPEG audio layer2, 48 KHz, Stereo
Is this what you want?
As I do want to keep all edited files in MPEG
So I take it Video Studio cannot do it
Chris
troppo
Post by troppo »
I don't know about Video Studio, but you most certainly CAN keep your files as MPEG and edit them in MSP.
http://www.broomevideo.com
Devil
Post by Devil »
I'm no expert in VS, but I see no reason why you can't do the same there, either.
sayer
CONVERT FILES
Post by sayer »
My problem is I have a lot of MPEG files?
Which I need to edit in MS8 or VS11
When I have done that,
I need to transfer them back to MPEG
Can this be done??
If so how??
Thanks :oops:
I've locked the duplicate post in the DVDMF forum, where I've posted a reply...
http://phpbb.ulead.com.tw/EN/viewtopic. ... 409#165409
In VS or MSP you need to render your project, which is either a VSP file (VideoStudio) or DVP (MediaStudio). These are nothing more then notepad-like files full of instructions for the respective programs. During the editing your original MPEG video files are left untouched.
So if you're using MSP, once all editing is complete, go to the File menu and select Create Video File.
In VS, go to the Share step, select Create video File.
Once you have created your new DVD Compatible MPEG-2 file(s), you can then use DVDMF to construct your menus, and burn your DVDs...
