QUALITY ISSUE IN BOTH VS 7 and 9
teekay
Post by teekay »
Why is the video rendered so poor and flickering when played on TV ?
The video clips captured looks fine when played before rendering . But after a VCD, SVCD or DVD is created the video looses more quality. Is there a way to improve this ?
Teekay
MikeGunter
Post by MikeGunter »
My projects look fine.
Are you using PAL or NTSC? What are the project's settings and how are you capturing the content?
Mike
teekay
Post by teekay »
I capture from vhs using grabster 400 and my project is pal.
The video looks fine on pc but flicker after rendering.
thanks
teekay
MikeGunter
teekay wrote:I capture from vhs using grabster 400 and my project is pal.
thanks
teekay
Check your Project Properties, and under the General tab, change the field order.
Mike
Pierredc
Post by Pierredc »
You all seem to be able to capture analog signals using videostudio and terratec 400 grabster.
My experience is different : no capture at all from the grabster with videostudio 7 SE, but capture is fine with DVD MovieFactory 3... which solves my problem.
Might be you can give me some suggestion on what is going on?
Regards
