cannot start the capture graph??
Posted: Sat Aug 23, 2008 4:49 pm
by master0010
Im trying to capture a video from a Sony Handycam Vision with a Dazzle dcv 90 to AVI. But i always recive a error massage:
- cannot start the capture graph;
Can somebody help me??
Posted: Sat Aug 23, 2008 11:06 pm
Welcome to the forums,
Can you give us the exact model of your Sony, please? If it is a mini DV tape model, then you should not be using the Dazzle to capture from it. Instead, you should be using the camera's firewire connection (called i-Link by Sony), and for that you need both a firewire cable and a firewire card in your computer.
Posted: Sun Aug 24, 2008 12:33 am
by master0010
Video Hi8 - i think this is the name....
But i didint find any i-Link port....
Posted: Sun Aug 24, 2008 2:38 am
No, that is an older analogue model, well before Firewire was developed. And yes, you need a device like the Dazzle to capture from it. But did the Dazzle come with any software? It used to come with an older version of Video Studio which may have been tweaked to work with it, whereas a newer version of Video Studio won't be able to capture from it. So we need to know what version of VS you are currently using and what software the Dazzle came with.
Same problem - Canon Elura 100
Posted: Sun Aug 24, 2008 5:58 pm
by amcooper
I am using version 11 plus and get the same error. I have a Canon Mini DV Elura 100 camcorder. An help would be appreciated. I could capture fine in version 10.
Posted: Sun Aug 24, 2008 6:12 pm
VS changed their capture plug-in (to conform to Vista) and it has caused problems for some people. If you can capture with v10 then do that, then open v11 and simply import the clips.
Re: Same problem - Canon Elura 100
Posted: Sun Aug 24, 2008 6:18 pm
amcooper wrote:I am using version 11 plus and get the same error. I have a Canon Mini DV Elura 100 camcorder. An help would be appreciated. I could capture fine in version 10.
With what are you capturing and to which format are you attempting to capture to?
Mini-DV camcorders should be equipped with Firewire. This is basically a real-time transfer of data. Have you checked to make sure the connections are all secure? Does Windows (and which Win OS) recognize your camcorder being connected and turned on?
One main difference between VS10 and 11 is the capture plug-in. VS10 used the VFW/DS while VS11 uses Intervideo's creation of IVI, which still allows DV transfer via Firewire.
Have you recently updated DirectX? Go
HERE and download the latest MS Direct-X drivers. The most current is dated June, 2008.
Please complete your
System Information in your profile. Clicking on this button -->
will take you to a short tutorial, explaining how to find and complete that information. This way it will always be available, and will save you from retyping it in the future.
Posted: Sun Aug 24, 2008 7:32 pm
by amcooper
Still getting same problem. I am attempting to capture to AVI format using Firewire. I am using Vista SP1. I was able to capture using another program so my connections should be fine. I just updated MS DirectX drivers. I also updated profile.
Posted: Sun Aug 24, 2008 7:45 pm
Then you might try BlackLab's suggestion of using VS10 to capture, or Try using the
free capture utility called
WinDV. It works with Firewire only, and captures DV. Several of us use it over VS or MSP capture.
