Disk-space meter in DVD MovieFactory ver. 3
AlexK
Post by AlexK »
In the edit window in the bottom, there is the disk-space meter bar, and near its right end, before the maximum capacity value 4.70 (4.38 ) GB, there are two vertical YELLOW and red dotted lines. The meaning of the YELLOW line is nowhere explained in the manual.
I guess it is not recommended to exceed the yellow-line limit, but what may happen, if I do?
Thank you.
The program has to guess how large your completed program is likely to be.
RED means definitely over, Green definitely under, Yellow - program not too sure - you have to try it and see.
If its only slightly over then best bet is to burn to a hard drive folder rather than a disc and then you can use DVD Shrink to get it down that last little bit.
AlexK
Post by AlexK »
Thank you.
But if it burns OK on a DVD, while over the yellow line, can I be sure that the DVD will be OK without any omissions/corruption?
Yes it will be fine.
Why take the risk of a ruined disc though - I always burn to a hard drive folder and then burn that onto a disc later.
This enables me to do a final check of the DVD with a software player such as WinDVD or PowerDVD. I can also make last minute alterations with MenuEdit or PGCEDit to improve the button sequence.
AlexK
Post by AlexK »
Thank you very much for your advice!
GregK
motherboard: MSI Aspen 1.0
processor: 2.50 gigahertz AMD Phenom 9850 Quad-Core
ram: 8gb
Video Card: Hauppauge WinTV HVR-1290
Hard_Drive_Capacity: 700gb
Post by GregK »
sjj1805 wrote:Yes it will be fine.
Exactly....I would say never do a direct-to-disc burn. I always create an ISO file.
