Removing periodic noise from an image
tsiozos
motherboard: Surface Pro 3
processor: Intel i7
ram: 8 Gb
Video Card: Intel 5000 HD
Hard_Drive_Capacity: 512 Gb
Monitor/Display Make & Model: 12.4 " Surface
Corel programs: Paintshop Pro, Videostudio
Post by tsiozos »
I have the following scanned photo and I want to remove the periodic pattern saving as much as possible of the detail. Any suggestions?
I've already tried Median Filter and moire pattern and digital noise reduction filters but they give a staircase-like pattern in the hair edges and elsewhere.
Prevention is better than cure.
Check your scanner settings for a "Descreen" setting.
Here is an article on the subject.
If you still have the original image you might be better scanning again with the appropriate settings.
tsiozos
processor: Intel i7
ram: 8 Gb
Post by tsiozos »
Thanks Steve.
Although my scanner doesn't have a descreen option, scanning at double the res, then a median filter then downsampling reduced the noise to acceptable levels. 8)
