I am using Windows XP Professional SP3 and I have 2 Hard drives. One for the operating system and one to store my videos (320GB) that I produce using Ulead (Corel now) VideoStudio 11.5+. Everything works fine but when I want to copy or cut or to just view the properties of these files on my second drive, using Explorer, when I put my mouse on the particular file (usually +/- 5,000,000KB) then I get the following message:
" The instruction at " 0x052b415b" referenced memory at "0x00000000". The memory could not be "written"
Click OK to terminate the program
Click CANCEL to debug the program,"
Any idea why do I get this?
Stelios
Explorer does not "explore"
- jparnold
- motherboard: Gigabyte Z390 UD
- processor: Intel Pentium i7 9700 3dot6Ghz
- ram: 16GB DDR3
- Video Card: Gigabyte RTX2060 OC 6GB
- sound_card: Onboard Realtec ALC887
- Hard_Drive_Capacity: 2048Gb mix
- Monitor/Display Make & Model: Samsung S27C450B
- Corel programs: Videostudio X10, Paint Shop Pro 2018
I do not know what is causing this problem but I would try splitting that large video file into small files and then check to see if the problem continues. I am guessing that explorer cannot handle files larger than 4096000.
Let me know what happens.
John a
- jparnold
- ram: 16GB DDR3
(Hi Ken)
I'm not sure if the system would store a file that large if the HD was formatted at FAT32. I thought of that too which makes the problem even more interesting (if the system allowed such a large file to be written to disk why can't explorer select it) - it's strange.
John a
Ah yes -- wasn't thinking straight. The mouse hover was the clue I overlooked. Since the file over 4 GB is there, it must be NTFS...
It's just that I have FAT32 on the brain recently as the Sony PlayStation 3 will only see FAT32, and thus the high definition files it will play (brilliantly) must be under 4 GB... But that doesn't help Stelios...
