Do not convert compliant MPEG (MF 7)
randazzo
Post by randazzo »
Although I ticked the box (do not convert) MF7 starts to re-render the compliant MPEG file. Any one else the same experience?
Jean-Pierre Randazzo
Post by Black Lab »
Did you add or change anything in your project? If so it will re-render.
randazzo
Post by randazzo »
It's an mpeg generated from Videostudio and not changed in DVD MF 7.
GregK
motherboard: MSI Aspen 1.0
processor: 2.50 gigahertz AMD Phenom 9850 Quad-Core
ram: 8gb
Video Card: Hauppauge WinTV HVR-1290
Hard_Drive_Capacity: 700gb
Post by GregK »
Black Lab is right....I only have MF6, and I've noticed that even the slightest little difference between the input file and the project settings, even a difference in bitrates, will initiate re-rendering. At least in MF6, when I have a file which perfectly matches my project settings, I can run the project off (I usually do an ISO file) in 15-20 minutes.
Post by Black Lab »
You are right Greg. The output settings must match the file settings EXACTLY for no re-rendering to take place.
lazael
Post by lazael »
For smart render, I think that the project settings can differ from those of the clips provided that the latter's properties are better than those of the project. No re-render will take place.
However, even if compliant, doing any cutting will result in a re-render. Not too sure why they haven¡¦t fixed this in MF7. To prevent this do a fast export of the edited video and re-import the resultant back into the project.
etech6355
Post by etech6355 »
I've read this thread a few times and it doesn't make any sense.
If MF is re-encoding your video then it's not compliant for the project.
Maybe a discussion on how the "Project Settings" work versus the
"Fast Export Project X Compliant" and also "Fast Export" features, and also including exporting your custom templates versus customized rendering.
But the first poster simply says MF is rendering his mpeg file, yet, no other descriptions of the actual mpeg file.
Therefore:Start here:
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=8960
The "Project Settings" do not always have to equal your source videos, it depends. Generally that is a good rule of thumb, but MF will still smart-render your video and can also ignore your "Project Settings" depending on how your using it.
randazzo
Post by randazzo »
I moved up from MF3. I always rendered the mpeg files directly from VS. MF3 never re-rendered these files even if they were different from the project settings.
etech6355
Post by etech6355 »
Try this, Under the "GEAR" Icon also check ON the "X-Disc" box.
The files may have something in them that MF considers non-compliant.
That should work if previous versions were not re-encoding the video(s).
If it doesn't then post the properties of your source video(s), because this is not happening on my machine.
I have both options checked ON under the "GEAR" Icon.
etech
randazzo
Post by randazzo »
Thanks. I'll try that.
BTW file properties were:
mpeg2
720x576
VBR 8000
16:9.
lion2008
Post by lion2008 »
etech6355 wrote:Try this, Under the "GEAR" Icon also check ON the "X-Disc" box.
etech
Great trick - I could have saved two nights of frustration if had known before that I have to check the "X-disc"-box as well !! :roll:
In addition, if MF6+ considers the file including h.264-Video not to be compliant for not re-encoding, it will re-encode to MPEG2 even if your settings do match the original values of the videofile. I finally got it without re-encoding by first demuxing the .ts-file with tsMuxeR and then joining the video- and the audio-stream again with tsMuxeR - with all settings unchanged in tsMuxeR ! Apparently, the header information of the .ts-file must correctly match with the requirements of MF6+ in order to avoid re-encoding :shock: . Once I have applied this workaround, the h.264-file will even be burned without re-encoding if the video is 25fps (1080i50) from European HDTV, provided that you have choosen "PAL/SECAM" in your preferences :P
