Bit rate for slideshows
Berzelius
- Hard_Drive_Capacity: 2TB
- Corel programs: VS X10 Ultimate; VS X7 Pro; VS 11Plus
I've just completed a slideshow project containing a number of titles, each of which I first converted to a video file at 4000kbps. It now occurs to me to wonder whether the bit rate is important for a slideshow where, except for any transitions, nothing actually moves. In other words, could I have used an even lower bit rate for producing the video files without any effect on the quality (except for transitions)?
I agree with Clevo. So if your slideshows play for around an hour or less, you could burn using an 8000 kbps bitrate for highest quality. And correspondingly lower the longer your slideshows last. They may originally be made up of still images, but they have been converted to video, and the same rule applies to the frames i.e. the lower the bitrate, the lower the final quality of playback.
Berzelius
Thanks for the reply. Following on from earlier advice in the forum I used 4000kbps as the total length is 1 hr 48 min. I was just wondering whether it was allowable to reduce the rate even further to make the video files smaller without loss of quality. Obviously the saying that there's no such thing as a free lunch applies here!Ken Berry wrote:I agree with Clevo. So if your slideshows play for around an hour or less, you could burn using an 8000 kbps bitrate for highest quality. And correspondingly lower the longer your slideshows last. They may originally be made up of still images, but they have been converted to video, and the same rule applies to the frames i.e. the lower the bitrate, the lower the final quality of playback.
