Since installing demo versions of MediaPro and DVD studio, I cannot import a movie from my Panasonic video camcorder.
The camera connects, and VideoEditor can see it, operate it and appears to be bringing the files in. But when I stop the capture process, I get an area saying the file is corrupt and will be deleted.
I've updated to V 9.0, same problem.
I run an AMD Athlon 2.6, 1Mb ram, Xp Pro SP2, 200Gb hard drive and a Panasonic DV camera. Until recently, its been working perfectly.
Corrupt file
Redstone
Redstone
THoff
thecoalman
maddrummer3301
THoff
ASUS doesn't make chipsets, they make motherboards, which are based on chipset from other companies such as VIA, Intel, and others.
In the case of the VIA chipsets, the drivers are known as the 4-in-1 (old name) or Hyperion (new name) drivers. They are required to allow many of the motherboard features to work correctly. There have been numerous issues with data corruption on IDE drives, as well as system lockups and sound issues (static, crackling) with Creative Labs SoundBlaster cards.
The VIA chipsets were very popular for AMD-based motherboards, so I would investigate whether this driver set is applicable to your system. The installer for the drivers is safe to run in all cases -- if it doesn't find a supported chipset, it will refuse to run. The drivers can be found HERE.
Regarding thecoalman's question, Microsoft has released a post-SP2 FireWire driver update for XP, but AFAIK that is only applicable to systems with IEEE 1394b (800Mb) FireWire.
One thing that I have seen cause problems for IEEE 1394a is when XP installs a network bridge for the FireWire adapter. If you don't network using FireWire and find that XP installed this component, remove it. You would also want to check if it enabled the Internet Connection Firewall (ICF) for the FireWire network adapter.
