MKV file conversion before using in DMF6
GregK
- motherboard: MSI Aspen 1.0
- processor: 2.50 gigahertz AMD Phenom 9850 Quad-Core
- ram: 8gb
- Video Card: Hauppauge WinTV HVR-1290
- Hard_Drive_Capacity: 700gb
I know that DMF won't accept the MKV format, so I need to convert it before importing it into DMF, but when I tried using that Super! program (which was recommended to me in another thread), the sound was out-of-synch. It probably had something to do with the settings I chose in Super! to keep as much of the high quality as possible....but can someone who knows the Super! program suggest what particular settings I should use when converting an MKV file inorder to keep the aspect ratio and original sound....bitrates and all that? I figured I should keep the original size and allow DMF handle the compression so my final project/disc will have really good quality.....but is it really necessary for me to have a huge filesize or can I convert the MKV to a standard DVD-compliant setting (which is usually 720x480/16x9) and have it look good? Do the bitrates of the converted file have to match the original bitrates to keep the sound in-synch? I figured Super! would be the best program for the conversion, but I've also noticed I can use Any Video Converter and VirtualDubMod to convert also (although VDM only converts to AVI).
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
skier-hughes
- Microsoft MVP
- ram: 4GB
GregK
- ram: 8gb
In other words, do a standard 720x480/16x9 MPEG2 conversion, just as I normally would for any other video file (such as AVI, etc.), right?
I'm running the conversion right now in Super!....will the fact that the source file is a higher resolution affect the quality of the downconvert at all? I'd assume that this, going from what I have (as I posted above), would look better than if I had started with something like an AVI file.
skier-hughes
- Microsoft MVP
- ram: 4GB
